rust and metal repair panels, posted in member vendor section |
dr914@autoatlanta.com |
Mar 11 2021, 10:58 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I was preparing a list of the rust and sheetmetal panels we manufacture for a wholesaler, and thought I would post it here as well:
As 914s become more popular, the values going WAY up, and owners holding on to the great cars, new entrants into ownership are having to deal with rougher cars to restore. As many of you know my slogan when I first started reproducing the panels in 1984 was "if you have no body, you have no car". and that proceeded me on my way to make many many repair panels to keep the 9114 on the road. Here is a list of everything we make: b914503031b fender dog leg left b914503032b fender dog leg right b91450303111a fender to cowl repair left b91450303211a fender tio cowl repair right b914531005a left lower door skin b914531006a right lower door skin B91450108910 left sill plate with two supports B91450109010 right sill plate with two supports B91450101310 left inner rocker panel B91450101410 right inner rocker panel B91450312510 left outer rocker panel B91450312610 right outer rocker panel B91450143410A right longitudinal upper B91450143410B right lower longitudinal B91450115310 jack post B91450115110 jack post support B91450194420C right inner wheelhouse B91450158710 battery tray B914503908gt gt steel flare set of four B91450390310DJ left door jamb B91450390410DJ right door jamb B91450164315 left inner firewall B91450164415 right inner firewall B91450111920a left outer firewall B91450111920a right inner firewall B91450394310 left sail panel B91450394310 right sail panel B91450143612 914 engine shelf B91450182510 engine bay c channel B914503903DC door catch reinforcement B91450704110 left floor pan triangle B91450704210 right floor pan triangle B91450110910 left floor pan crossmember B91450111010 right floor pan crossmember B91450108320 rear trunk floor b91450107510 914 emergency brake handle stand B91450103010 rear trunk hinge cup bracket B91450104411 right rear suspension console b91461801310 control unit bracket b91460201100 914-6 control unit bracket B91451219110 trunk hinge bolt if you need anything they are easily ordered from our website, and if you need advice as to exactly which part you need to repair your 914, do not hesitate to send pictures or call and send pictures. We can give you some good guidance as how to repair. 914s are simple cars and therefore not too difficult to restore perfectly. Best thing is that at the end, you will have a great driving dependable sports car! |
Lo-Fi Version | Time is now: 18th May 2024 - 07:21 PM |
