1974 Porsche 914-4 Restoration, I'm restoring a 1974 chassis with a 1972 engine |
GeorgeKopf |
Mar 14 2021, 05:50 PM
Member Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
Today marks the official beginning of my 1974 Porsche 914-4 restoration project.
I'm hoping to have the car on the road before its 50 anniversary. |
GeorgeKopf |
Mar 24 2022, 08:06 PM
Turns out my powder coating oven is not big enough for the larger parts so I found an automotive media blasting/powder coating shop and dropped off all of the big stuff. I'm still blasting and coating the smaller bits.
Also, I've had good success with Zinc plating but can't get the yellow chromate to stick. |
friethmiller |
Mar 25 2022, 12:38 PM
Member Group: Members Posts: 476 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I've had good success with Zinc plating but can't get the yellow chromate to stick. George, First off, I think you are doing great work on your car! It's coming along. I had this same issue the first time I tried plating. I did both zinc-nickel and zinc plating and I can tell you, that while I like the durability of the zinc-nickel better, the plain zinc was much easier to do. Make sure your zinc plates are covered with the provided cheese cloth. Temps are important and you must make sure things are very clean. IMO, if you follow the instructions and prep things correctly, you should start to see better results with the chromate sticking. Here's a link to my "plating" pics with comments. https://fredriethmiller.smugmug.com/1974-Po...Apr-Jun-2020/59 BTW, I just got finished a 4-year full restoration on my '74 914. Welcome to look into the other galleries, as well (https://fredriethmiller.smugmug.com/1974-Porsche-914). |
Lo-Fi Version | Time is now: 18th May 2024 - 05:47 PM |
