| GeorgeKopf |
May 5 2025, 07:11 PM
Member ![]() ![]() Group: Members Posts: 270 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
The wiring harness is in. I connected the battery and turned the ignition, and the dash lights came on.
![]() ![]() ![]() ![]() ![]() I refurbished the gauges and powder coated the bezels. ![]() ![]() |
| Geezer914 |
May 5 2025, 07:23 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,387 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Very nice!!!
| GeorgeKopf |
Jun 8 2025, 08:15 PM
I have made a ton of progress these last few weeks. I have installed and tested:
1. the wiring harness, 2. refurbished the steering column, 3. the wiper and turn signal switches, 4. the fuse panel (and all the relays), 5. all three gauges, 6. the front headlights (and the motors), 7. the fog lights, 8. the horns, 9. the turn signal/running light buckets, 10. tail lights, 11. door switches, 12. dome light 13. seat belt buckles (and fasten seatbelt warning buzzer and light), 14. Heater/Air Control panel, 15. Cigar lighter, 16. Engine/trunk light, 17. Ignition switch, 18. Hazard light switch, 19. license plate lights, This was a lot of work. I installed the wiring harness and then had to take it out to replace the snorkel and reinstall it. I had to disassemble and refurbish the headlight motors, the seatbelt buckles, all three gauges, debug and replace the hazard flasher, modify the high beam wiring to accommodate my LED headlights, un DAPO the door switch wiring, etc. It seems that every task devolves into a complicated project of research and trial and error. George Attached image(s)
| dtmehall |
Jun 8 2025, 08:40 PM
Member ![]() ![]() Group: Members Posts: 403 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
| GeorgeKopf |
Jun 22 2025, 01:17 PM
So much progress!!!!
1. Wiper motor installed and tested. 2. Fresh air box installed and tested. 3. Tested the wires to the windshield washer pump. 4. Tested the wires to the fuel pump. .....a. Had to jumper the relay board since I'm using carburetors. 5. Heater fan switch and motor installed and tested. 6. Parking brake switch and idiot light installed and tested. 7. Center console gauges: .....a. Clock installed and tested. .....b. Voltage gauge installed and tested. .....c. Oil pressure gauge installed and tested. 8. Oil pressure idiot light. The only thing left, related to the electricals, is the fuel sender, the fuel gauge and the low fuel idiot light. The hardest part was installing the fresh air box with the oversized 914Rubber seal. Thank you to Ian Karr for making the YouTube video. I used the rubber band trick but didn't take my hood off. I ended up wedging a bunch of sheets of wood under fan housing and using a spreader to push the box towards the back. ![]() George |
| slowrodent |
Jun 22 2025, 02:02 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region
You are really doing some fine work there George... And you seem to be moving along quite well.. Keep it up. (IMG:style_emoticons/default/popcorn[1].gif)
| friethmiller |
Jun 22 2025, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,624 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Looking good! (IMG:style_emoticons/default/popcorn[1].gif)
| GeorgeKopf |
Aug 11 2025, 06:19 PM
More progress.
I cleaned up my brake calipers and the pressure regulator and had them zinc plated. Refurbished my pedal cluster and installed the master cylinder and brake fluid reservoir. I installed the parking brake cables and the handle. I also installed colored LED lights all the way around. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Aayala |
Aug 19 2025, 02:07 PM
Member ![]() ![]() Group: Members Posts: 60 Joined: 7-July 25 From: Austin Tx Member No.: 28,874 Region Association: South East States |
This is amazing progress and documentation! I am about to start my own 914 rebuild and this is seriously inspiring me! Thank you!
Question, what is the best method you found for cleaning some of these rusted and grimy parts like the break calipers etc? Are you sending them off to get them cleaned as well or are you doing most of that before having them zinc coated? |
| friethmiller |
Aug 19 2025, 02:23 PM
Been watching this one for a while. (IMG:style_emoticons/default/popcorn[1].gif) Great work! I remember doing all this on my last build. It's fun once the car is painted. It's a series of "weekend restorations" to get all the components ready to go, back on the car, and working.
| Artfrombama |
Aug 19 2025, 07:10 PM
Artfrombama ![]() ![]() Group: Members Posts: 496 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
The car is gonna be awesome!!
Been a follower/subscriber since I came here! |
| Root_Werks |
Aug 21 2025, 04:15 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,097 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Haven't looked at this thread in a while, wow! Some great progress!
Alaska Blue? Love blue on a 914. |
| 930cabman |
Aug 21 2025, 06:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,887 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
lookin good, great progress
engine/transmission? |
| iankarr |
Aug 24 2025, 07:31 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,613 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Looking good!
| GeorgeKopf |
Sep 12 2025, 07:11 AM
Working on populating the center tunnel. Just ordered the stainless steel fuel lines from Tangerine Racing. Chris was a huge help!!!
In the meantime, I installed the grill and letters on the engine bay lid. ![]() George |
| GeorgeKopf |
Sep 30 2025, 02:01 PM
I've been working on "stuff that goes in the tunnel".
I installed the heater control wire, the speedometer cable, stainless steel fuel lines, the shift linkage and the brake line. I ordered a new clutch cable and once that is in the tunnel is complete. George |
| GeorgeKopf |
Nov 6 2025, 03:02 PM
Spent a week de-rusting the inside of the tank. Scraped the sacrificial rod every evening and by the end the tank looked pretty good.
![]() ![]() ![]() ![]() ![]() Then I used the KBS tank sealing kit. The "Klean" removes all gas varnish and dirt, the "Blast' is an acid bath that removes surface rust and etches the tank, and the sealer is an epoxy like coating. ![]() I installed a low-pressure pump for carburetors. ![]() I removed all the paint, primer and rust from the exterior and repainted. ![]() I also installed a fuel pump cut-off switch next to the brake fluid reservoir. ![]() George Attached image(s)
| Cairo94507 |
Nov 6 2025, 04:02 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,802 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Great work and progress. (IMG:style_emoticons/default/beerchug.gif)
| GeorgeKopf |
Jul 5 2026, 10:23 PM
Lots of progress. I've started working on the exterior components.
Installed the main targa top seal, the window seals, the targa top and those seals. Rekeyed and installed the trunk and frunk locks. Attached the front and rear bumpers. Polished and attached the running boards. Polished and installed the Fuchs. Refurbished the platform in the frunk. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Attached image(s)
| GeorgeKopf |
Nov 22 2026, 10:33 PM
Lots of progress on the 74. I reupholstered the seats and refurbished the brackets. The seats are installed.
![]() ![]() ![]() I'm stuck waiting on new vinyl for the door cards and the backpad. After that I have the A & B pillars, carpeting and installing the rear window and windshield. While I'm waiting I decided to tackle the engine and transmission. ![]() ![]() I'm going to build a 2056 with 40mm weber carbs. I've already sourced the 2.0 heads, 2.0 tin and 2.0 heat exchangers. I disassembled the engine and split the case. Everything just came apart like it is supposed to. I didn't have to use the blow torch or breaker bars. I didn't break or strip any bolts. ![]() Now I need to figure out what services I need performed on my case, rods, heads and crank. Everything else will be new. George |
Lo-Fi Version | Time is now: 23rd November 2026 - 01:53 AM |
