Street Track Car - Roll Hoop and belt suggestions |
BillJ |
Mar 31 2021, 08:25 AM
Senior Member Group: Members Posts: 1,091 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
If you are using HANS I prefer the 2" harness straps on the shoulder as they fit better on the device. Running a 6 point or 5 point is best (using a 6 point this weekend at VIR)
mlindner |
Apr 8 2021, 03:53 AM
Senior Member Group: Members Posts: 1,511 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Racer |
Apr 8 2021, 11:13 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Something else to consider but I didn't see mentioned:
"Equal restraints for driver and passenger".. No instructor wants to sit in a stock seat and 3pt belt when you have a race seat and harnesses. So, x2 when you replace your seats/harnesses. And as someone else mentioned, it doesn't have to be a "race" to be an accident.. DE.. High speed.. 1970s' weak sheet metal between you and impact. Safety is somewhat personal and you decide the minimum you want.. but realize that the insurance underwriting the events is what is driving the minimums standards up. Stock seat with harnesses was fine (well, allowed maybe is more accurate).. in the 1990s.. its not fine today. On my '76, the car had a Safety devices bolt in cage that was welded in. It also had stock seats. ugh. Pulled out the back pad, had a harness bar installed at the correct height and replaced the stock seats with some Kirkey Aluminum road race seats. Reasonably comfy. very nice when driving on the track. |
Justinp71 |
Apr 14 2021, 10:09 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Something else to consider but I didn't see mentioned: "Equal restraints for driver and passenger".. No instructor wants to sit in a stock seat and 3pt belt when you have a race seat and harnesses. So, x2 when you replace your seats/harnesses. And as someone else mentioned, it doesn't have to be a "race" to be an accident.. DE.. High speed.. 1970s' weak sheet metal between you and impact. Safety is somewhat personal and you decide the minimum you want.. but realize that the insurance underwriting the events is what is driving the minimums standards up. Stock seat with harnesses was fine (well, allowed maybe is more accurate).. in the 1990s.. its not fine today. On my '76, the car had a Safety devices bolt in cage that was welded in. It also had stock seats. ugh. Pulled out the back pad, had a harness bar installed at the correct height and replaced the stock seats with some Kirkey Aluminum road race seats. Reasonably comfy. very nice when driving on the track. @Racer I've been thinking about the kirkey seat. I actually pulled one out of my track car last night and it fits pretty well. My only compliant was its kind of tall and rests on the rollbar with my long legs. Do you have any pictures of your install? Also did you just fabricate a harness bar into your roll hoop? |
Racer |
Apr 14 2021, 01:47 PM
Something else to consider but I didn't see mentioned: "Equal restraints for driver and passenger".. No instructor wants to sit in a stock seat and 3pt belt when you have a race seat and harnesses. So, x2 when you replace your seats/harnesses. And as someone else mentioned, it doesn't have to be a "race" to be an accident.. DE.. High speed.. 1970s' weak sheet metal between you and impact. Safety is somewhat personal and you decide the minimum you want.. but realize that the insurance underwriting the events is what is driving the minimums standards up. Stock seat with harnesses was fine (well, allowed maybe is more accurate).. in the 1990s.. its not fine today. On my '76, the car had a Safety devices bolt in cage that was welded in. It also had stock seats. ugh. Pulled out the back pad, had a harness bar installed at the correct height and replaced the stock seats with some Kirkey Aluminum road race seats. Reasonably comfy. very nice when driving on the track. @Racer I've been thinking about the kirkey seat. I actually pulled one out of my track car last night and it fits pretty well. My only compliant was its kind of tall and rests on the rollbar with my long legs. Do you have any pictures of your install? Also did you just fabricate a harness bar into your roll hoop? @Justinp71 I had the seat affixed to the floor (no sliders) and then had harness bars welded behind the seat that ran from the vertical of the rollbar to the center "hump" of the backwall. By mounting to the floor, I got much more headroom clearance than I expected. Here are a few of the interior pics I could find: Attached image(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 01:08 AM |
