OEM Black Door Handles |
pfreiburger |
Mar 27 2021, 05:15 AM
Member Group: Members Posts: 110 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None |
I am now quite certain that the factory did install some black door handles. I came to this determination in a roundabout (and expensive) way, starting when my inner hammer mechanic escaped and broke the driver door handle.
As no black ones exist, I picked up a new chrome (Sierra Madre) handle and was surprised to find that my old lock cylinder (after removing the black paint) would not fit the chrome handle. The length was fine, but it fit so tight it could not be turned. At all. Measuring the ID of the handle bores confirmed that the black handle was larger, even with paint on it. The used chrome-handle lock cylinder I bought on line later fit and turned in the new chrome handle just fine. And that used chrome handle cylinder definitely had more clearance when inserted in the old black handle. Measuring the cap ends of the lock cylinder confirmed it – the cylinder from the black handle was larger in diameter. Dissimilar sized handle components are almost certainly no customizer job, and damn sure no hot rod job. The only conclusion I can draw is that Porsche had a supplier make a run of black handles, and for whatever reason some components were made a little different. This fits with what I found when I scraped some black paint from the broken handle: no evidence of chrome ever being applied to the casting. Lastly, there are factory pictures (albeit poor ones) of black A pillar cars that look like they have black handles also. Am I missing another explanation? |
wonkipop |
Apr 5 2021, 05:17 PM
Advanced Member Group: Members Posts: 4,315 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
i found this image in my file of stuff i collected over the years.
can't remember source, too long ago. never bothered to look at it closely before. assumed it was another shot of red 4 above. took a second look and thought again - a shot of piech 8 in first form? - a very early prototype test car. looked again, its not piech 8 unless it was heavily modded again after this. running 4 bolt vw wheels and has flattened front wheel arches. but it does seem to have wide twin headlight pop up panels. bumper has no grilles. |
SirAndy |
Apr 6 2021, 10:17 AM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i found this image in my file of stuff i collected over the years. can't remember source, too long ago. never bothered to look at it closely before. assumed it was another shot of red 4 above. took a second look and thought again - a shot of piech 8 in first form? - a very early prototype test car. looked again, its not piech 8 unless it was heavily modded again after this. running 4 bolt vw wheels and has flattened front wheel arches. but it does seem to have wide twin headlight pop up panels. bumper has no grilles. Yes, that is 914.111 before it got the 908 treatment. (IMG:style_emoticons/default/bye1.gif) |
wonkipop |
Apr 6 2021, 10:09 PM
i found this image in my file of stuff i collected over the years. can't remember source, too long ago. never bothered to look at it closely before. assumed it was another shot of red 4 above. took a second look and thought again - a shot of piech 8 in first form? - a very early prototype test car. looked again, its not piech 8 unless it was heavily modded again after this. running 4 bolt vw wheels and has flattened front wheel arches. but it does seem to have wide twin headlight pop up panels. bumper has no grilles. Yes, that is 914.111 before it got the 908 treatment. (IMG:style_emoticons/default/bye1.gif) found this story sir andy, you probably already read it. mechanic who built 914.111 is still alive. says he also built (handbuilt?) the first two 914/4 prototypes. https://www.porscheclubnews.com/prod/clubs/...4_914clausecker |
Lo-Fi Version | Time is now: 20th May 2024 - 05:57 PM |
