FS GC code 2.0 almost complete engine, Case GC003110 equipped with bus heads |
barefoot |
Mar 29 2021, 04:11 PM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
All parts except alternator, induction system, & clutch. Case had been align bored .020 and oil galleys capped with threaded plugs. Crank at standard journal size shows slight scoring, so needs first U/S grind. Cylinders show some corrosion, need O/S boring or replacement. Flywheel shows very slight corrosion pits in rear main seal area, so may be paper weight.
P/N 022 101 372G 48cc bus heads in vg condition, no cracks evident and spark plug holes clean. Exhaust studs OK all valve gear included. Fan has 1 missing blade All tins & fan sand blasted and epoxy primed, then some tins rattle can painted. Note that top tins have spark plug holes in the 1.7/1.8 location to match bus heads. Cam is unknown aftermarket, no ident seen, 2 sets of lifters included. All other parts not shown here. Should be considered a CORE. 2 bottom most tins that fit under headers NOT included. Looking for $350 plus shipping. Prefer to keep it all together unless no other options arise. Here's a few photos, can show more if needed. |
barefoot |
Apr 7 2021, 06:46 PM
Bump
Part it out or complete package ?? Barefoot |
Lo-Fi Version | Time is now: 17th April 2024 - 04:20 PM |
