My latest challenge. Here we go again., 72 restoration and conversion to a Subaru EZ30R engine. |
rmarx |
Apr 3 2021, 11:09 PM
Member Group: Members Posts: 95 Joined: 5-June 07 From: Pleasant Hill, CA Member No.: 7,784 |
It had been about eleven years since my last 914 build. It was shown on the cover of the January 2010 Retro Cars Magazine. It was a 72 with a 327 Chev small block, GT flares , 5 lug conversion and a long list of modifications. I have spent the last eleven years building , restoring , highly modifying two separate 912s. One was converted from a short to long wheelbase RSR, the other was a 69 912 converted to an R Gruppe style 911. I have owned about eight 914s over the years and I always seem to be drawn back to their mid-engined targa topped allure.
About a year and a half ago, I obtained a 72 roller from fellow 914 world enthusiast Brian Adkins. He was nice enough to give me a good dal on the car, so it was time to begin my next crazy idea. I am installing a 2004 Subaru EZ30R engine with an 04 WRX transmission converted from four to two wheel drive. The trans is very strong and able to handle all the power I want to throw at it. It will have a hydraulic clutch and operated by a Cable system. The engine will be operated with an ECU Master computer. The power output should be in the 280-300 hp range per the experts that use these motors in sand rail conversions. The car initially received a 1.7 four generously donated by Chris Baker (Tyga Boy). I got the car running well enough to participate in last year's West Coast Rally. I actually won an award for Best Patina ( Best Shit Box) . I have since pulled the motor and trans, stripped the paint, collected most of the parts needed for the conversion and will install the new drivetrain very soon. It is my intention to show many pictures and details of the process. Many thanks to to all those that have in the past and in the future helped me to achieve my goals for this project. I couldn't do it without hem. |
rmarx |
Apr 12 2021, 04:50 PM
Yes
76-914 |
Apr 13 2021, 11:17 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yes Well that's that. If you aren't planning on AC you can 86 the comp & PS pump and relo the alt to center of engine (as others have done) thus allowing you to flip the intake. I like your approach to making the shroud. Good choice on the radiator. Did you need to purchase the fans separately of was it a package deal? Also, when you get to it post up the ECU and map you will be using. (IMG:style_emoticons/default/beerchug.gif) |
rmarx |
Apr 13 2021, 12:34 PM
Yes Well that's that. If you aren't planning on AC you can 86 the comp & PS pump and relo the alt to center of engine (as others have done) thus allowing you to flip the intake. I like your approach to making the shroud. Good choice on the radiator. Did you need to purchase the fans separately of was it a package deal? Also, when you get to it post up the ECU and map you will be using. (IMG:style_emoticons/default/beerchug.gif) The alt is already at the center. A future post will reveal. The fans came with the radiator. I will be using ECU Master for the ECU. They seem to be set up for the vario cam and fly by wire throttle, and it's more affordable than some of the other products out there. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:01 PM |
