My latest challenge. Here we go again., 72 restoration and conversion to a Subaru EZ30R engine. |
rmarx |
Apr 3 2021, 11:09 PM
Member Group: Members Posts: 95 Joined: 5-June 07 From: Pleasant Hill, CA Member No.: 7,784 |
It had been about eleven years since my last 914 build. It was shown on the cover of the January 2010 Retro Cars Magazine. It was a 72 with a 327 Chev small block, GT flares , 5 lug conversion and a long list of modifications. I have spent the last eleven years building , restoring , highly modifying two separate 912s. One was converted from a short to long wheelbase RSR, the other was a 69 912 converted to an R Gruppe style 911. I have owned about eight 914s over the years and I always seem to be drawn back to their mid-engined targa topped allure.
About a year and a half ago, I obtained a 72 roller from fellow 914 world enthusiast Brian Adkins. He was nice enough to give me a good dal on the car, so it was time to begin my next crazy idea. I am installing a 2004 Subaru EZ30R engine with an 04 WRX transmission converted from four to two wheel drive. The trans is very strong and able to handle all the power I want to throw at it. It will have a hydraulic clutch and operated by a Cable system. The engine will be operated with an ECU Master computer. The power output should be in the 280-300 hp range per the experts that use these motors in sand rail conversions. The car initially received a 1.7 four generously donated by Chris Baker (Tyga Boy). I got the car running well enough to participate in last year's West Coast Rally. I actually won an award for Best Patina ( Best Shit Box) . I have since pulled the motor and trans, stripped the paint, collected most of the parts needed for the conversion and will install the new drivetrain very soon. It is my intention to show many pictures and details of the process. Many thanks to to all those that have in the past and in the future helped me to achieve my goals for this project. I couldn't do it without hem. |
rmarx |
Apr 15 2021, 05:42 PM
Here are pictures of the transmission I will be using. It is a 04 WRX 5speed. I had to fabricate a tool to lock the two shafts together so that I could remove an inner shaft bolt. I am missing the picture of the completed tool. What I did was cut two pieces of roll bar tubing, drilled holes in each piece to accommodate a rod that would hold it to the shaft. I used my tubing notcher to notch one end of each tube that would be welded to another piece of tubing that connects the two together. Pictures show the inner guts (shafts and gears) that were removed when converting the trans from four to two wheel drive. The final pictures show the new end plate that replaces the stock nose cone. If save about 5-6 inches in overall length of the trans while saving weight at the same time.
Attached image(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 07:19 AM |
