My latest challenge. Here we go again., 72 restoration and conversion to a Subaru EZ30R engine. |
rmarx |
Apr 3 2021, 11:09 PM
Member Group: Members Posts: 95 Joined: 5-June 07 From: Pleasant Hill, CA Member No.: 7,784 |
It had been about eleven years since my last 914 build. It was shown on the cover of the January 2010 Retro Cars Magazine. It was a 72 with a 327 Chev small block, GT flares , 5 lug conversion and a long list of modifications. I have spent the last eleven years building , restoring , highly modifying two separate 912s. One was converted from a short to long wheelbase RSR, the other was a 69 912 converted to an R Gruppe style 911. I have owned about eight 914s over the years and I always seem to be drawn back to their mid-engined targa topped allure.
About a year and a half ago, I obtained a 72 roller from fellow 914 world enthusiast Brian Adkins. He was nice enough to give me a good dal on the car, so it was time to begin my next crazy idea. I am installing a 2004 Subaru EZ30R engine with an 04 WRX transmission converted from four to two wheel drive. The trans is very strong and able to handle all the power I want to throw at it. It will have a hydraulic clutch and operated by a Cable system. The engine will be operated with an ECU Master computer. The power output should be in the 280-300 hp range per the experts that use these motors in sand rail conversions. The car initially received a 1.7 four generously donated by Chris Baker (Tyga Boy). I got the car running well enough to participate in last year's West Coast Rally. I actually won an award for Best Patina ( Best Shit Box) . I have since pulled the motor and trans, stripped the paint, collected most of the parts needed for the conversion and will install the new drivetrain very soon. It is my intention to show many pictures and details of the process. Many thanks to to all those that have in the past and in the future helped me to achieve my goals for this project. I couldn't do it without hem. |
rmarx |
Apr 16 2021, 10:40 AM
One thing I noticed about these Subaru motors is that all the bolts are on there really tight. Case in point, while removing the flywheel bolts, I had to use all my strength to break them loose. I got the first five to loosen up, the the remaining three would not budge. They are a female torx type bolt. I snapped the tool in half while trying to loosen them up and ended up stripping them all. Thats when that sinking feeling starts to creep in knowing that it could be a really expensive solution to getting the remaining bolts off the crankshaft. I tried vise grips, thread extractors and heat all to no avail.
The heads of the flywheel bolts are round and smooth and it's hard to get a good angle to grip them. Then I got an idea... I went to the hardware store and bought some nuts with an internal diameter of the exterior diameter of the bolt head. I slid them over the bolt head and welded the nut to the bolt head. I then bought a new socket to match the nut diameter and proceeded to attempt to remove the stuck bolt. It came out like butter. I posted my solution to help anyone who might find themselves in a similar hopeless situation. Attached image(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 06:22 AM |
