D-jet idle - one issue thats not been solved, low idle on start up for a few minutes hot or cold...... |
DRPHIL914 |
Apr 6 2021, 06:04 AM
Dr. Phil Group: Members Posts: 5,756 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
here is my set up, - its a '75 2.0 d-jet with very fresh and new in past 2 years everything,
,tested proper functioning AAr, CHT is the new 914rubberone, but same issue with my NOS one, no vac leaks , rebuilt throttle body MPS(ive tested 2 others one rebuilt by Jeff B same issue), etc etc , 123 distributor, anywayhere is what i have going on- i think i am around 1000 for a good steady idle, if its lower than that warmed up, then i cant get it to idle decent when cold for the first 2-3 minutes, even with AAr open, same with a hot start after running for a while, then shut off and turned back on after sitting foor a few minutes, heat sink on the CHT maybe, i have a feeling the resistance of the CHT is not correct, it is a NOS correct CHT but i am thinking about adding that resistor to the cht line- any thoughts? i have to feather or hold the pedal down just a bit for a minute or 2 then it comes up. like i said perfect idle around 950-1000 once on for a while or even stopped at light after running for a long time idle is perfect EXCEPT after turned off for a bit then back on-- Phil |
BeatNavy |
Apr 6 2021, 07:23 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Going over 300 is not an issue especially with hard driving. I understand north of 350 regularly may be cause for attention. Pushing or exceeding 400 not good.
On my 2056 I was D-Jet. On my 2270 I'm Microsquirt with an idle air control valve. On both I have the Raby cam, and, as mentioned, first start of the day requires a few blips of the throttle. I think I've heard others say the same thing. I hadn't heard about PMB's FI solution. I need to check that out. |
GregAmy |
Apr 6 2021, 07:31 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Lo-Fi Version | Time is now: 18th April 2024 - 12:48 AM |
