D-jet idle - one issue thats not been solved, low idle on start up for a few minutes hot or cold...... |
DRPHIL914 |
Apr 6 2021, 06:04 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
here is my set up, - its a '75 2.0 d-jet with very fresh and new in past 2 years everything,
,tested proper functioning AAr, CHT is the new 914rubberone, but same issue with my NOS one, no vac leaks , rebuilt throttle body MPS(ive tested 2 others one rebuilt by Jeff B same issue), etc etc , 123 distributor, anywayhere is what i have going on- i think i am around 1000 for a good steady idle, if its lower than that warmed up, then i cant get it to idle decent when cold for the first 2-3 minutes, even with AAr open, same with a hot start after running for a while, then shut off and turned back on after sitting foor a few minutes, heat sink on the CHT maybe, i have a feeling the resistance of the CHT is not correct, it is a NOS correct CHT but i am thinking about adding that resistor to the cht line- any thoughts? i have to feather or hold the pedal down just a bit for a minute or 2 then it comes up. like i said perfect idle around 950-1000 once on for a while or even stopped at light after running for a long time idle is perfect EXCEPT after turned off for a bit then back on-- Phil |
BeatNavy |
Apr 6 2021, 07:23 AM
Going over 300 is not an issue especially with hard driving. I understand north of 350 regularly may be cause for attention. Pushing or exceeding 400 not good.
On my 2056 I was D-Jet. On my 2270 I'm Microsquirt with an idle air control valve. On both I have the Raby cam, and, as mentioned, first start of the day requires a few blips of the throttle. I think I've heard others say the same thing. I hadn't heard about PMB's FI solution. I need to check that out. |
ClayPerrine |
Apr 6 2021, 07:56 AM
Life's been good to me so far..... Group: Admin Posts: 15,392 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
On both I have the Raby cam, and, as mentioned, first start of the day requires a few blips of the throttle. I think I've heard others say the same thing. Betty's 914 has a Raby 9590 cam in it, and it won't idle at all when it is dead cold. The AAR is working correctly, but it just won't idle (This is L-Jet, btw). After about 2 minutes of blipping the throttle, it will idle. But the extra performance of the 9590 cam is worth the extra trouble when cold. I think it is something to do with the cam profile. Clay |
BeatNavy |
Apr 6 2021, 08:04 AM
On both I have the Raby cam, and, as mentioned, first start of the day requires a few blips of the throttle. I think I've heard others say the same thing. Betty's 914 has a Raby 9590 cam in it, and it won't idle at all when it is dead cold. The AAR is working correctly, but it just won't idle (This is L-Jet, btw). After about 2 minutes of blipping the throttle, it will idle. But the extra performance of the 9590 cam is worth the extra trouble when cold. I think it is something to do with the cam profile. Clay That's good to know, Clay. I've spent many hours using all the tricks and tools Microsquirt gives you to try to resolve, and I never could. Agreed, the boost in performance is worth the small price to pay, particularly if you know that it kind of "is what it is." |
Lo-Fi Version | Time is now: 18th April 2024 - 08:59 PM |
