Bucci |
Bucci ![]() ![]() Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California ![]() ![]() |
Does anybody know what it would take to use this steering wheel on a 914.?
Thanks LEATHER STEERING WHEEL 911-347-082-00 ![]() ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,952 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Most guys don't use a 911 wheel in a 914 because they are pretty large in diameter and might rub your legs. 911 wheels have a Porsche hub, same as early 70-71 914's. For an early car, you just need the early plastic hub that has a metal horn cancel tab. You can use a later 72-76 plastic hub on this wheel to fit a 72-76 914. It will work but it's not optimal.
1970-1971 914's have a Porsche hub (flat front) that has a model number ending in "10" 1972-1976 914's have a VW hub (concave front and chamfer on the back of the hub) that has a model number ending in "11" |
Bucci |
Most guys don't use a 911 wheel in a 914 because they are pretty large in diameter and might rub your legs. 911 wheels have a Porsche hub, same as early 70-71 914's. For an early car, you just need the early plastic hub that has a metal horn cancel tab. You can use a later 72-76 plastic hub on this wheel to fit a 72-76 914. It will work but it's not optimal. 1970-1971 914's have a Porsche hub (flat front) that has a model number ending in "10" 1972-1976 914's have a VW hub (concave front and chamfer on the back of the hub) that has a model number ending in "11" Got it, thanks for the information. I’m looking for a stock replacement wheel for my 1972. Marc |
mepstein |
Most guys don't use a 911 wheel in a 914 because they are pretty large in diameter and might rub your legs. 911 wheels have a Porsche hub, same as early 70-71 914's. For an early car, you just need the early plastic hub that has a metal horn cancel tab. You can use a later 72-76 plastic hub on this wheel to fit a 72-76 914. It will work but it's not optimal. 1970-1971 914's have a Porsche hub (flat front) that has a model number ending in "10" 1972-1976 914's have a VW hub (concave front and chamfer on the back of the hub) that has a model number ending in "11" Got it, thanks for the information. I’m looking for a stock replacement wheel for my 1972. Marc Any wheel that part number ends in "11" will fit perfectly. |
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 888 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
Marc,
I have a couple of stock 914 steering wheels. Both are PN 914.347.804.11 Date codes are: Left one....12/72 Right one...7/75 These are the standard stock "hard rubber/plastic" type. You can as is or have them leather wrapped. They are good driver condition and can be cleaned up and used or repainted. I have more pictures....PM me if interested Thanks ![]() |
Bucci |
P.M. sent. thank you John.
Lo-Fi Version | Time is now: 30th June 2025 - 08:04 PM |
