911 steering wheel beauty/cancel ring, 911 steering wheel on at 914 |
Bucci |
Apr 6 2021, 08:36 PM
Bucci Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California |
Does anybody know what it would take to use this steering wheel on a 914.?
Thanks LEATHER STEERING WHEEL 911-347-082-00 |
mepstein |
Apr 6 2021, 09:12 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Most guys don't use a 911 wheel in a 914 because they are pretty large in diameter and might rub your legs. 911 wheels have a Porsche hub, same as early 70-71 914's. For an early car, you just need the early plastic hub that has a metal horn cancel tab. You can use a later 72-76 plastic hub on this wheel to fit a 72-76 914. It will work but it's not optimal.
1970-1971 914's have a Porsche hub (flat front) that has a model number ending in "10" 1972-1976 914's have a VW hub (concave front and chamfer on the back of the hub) that has a model number ending in "11" |
Bucci |
Apr 7 2021, 06:21 AM
Most guys don't use a 911 wheel in a 914 because they are pretty large in diameter and might rub your legs. 911 wheels have a Porsche hub, same as early 70-71 914's. For an early car, you just need the early plastic hub that has a metal horn cancel tab. You can use a later 72-76 plastic hub on this wheel to fit a 72-76 914. It will work but it's not optimal. 1970-1971 914's have a Porsche hub (flat front) that has a model number ending in "10" 1972-1976 914's have a VW hub (concave front and chamfer on the back of the hub) that has a model number ending in "11" Got it, thanks for the information. I’m looking for a stock replacement wheel for my 1972. Marc |
mepstein |
Apr 7 2021, 07:16 AM
Most guys don't use a 911 wheel in a 914 because they are pretty large in diameter and might rub your legs. 911 wheels have a Porsche hub, same as early 70-71 914's. For an early car, you just need the early plastic hub that has a metal horn cancel tab. You can use a later 72-76 plastic hub on this wheel to fit a 72-76 914. It will work but it's not optimal. 1970-1971 914's have a Porsche hub (flat front) that has a model number ending in "10" 1972-1976 914's have a VW hub (concave front and chamfer on the back of the hub) that has a model number ending in "11" Got it, thanks for the information. I’m looking for a stock replacement wheel for my 1972. Marc Any wheel that part number ends in "11" will fit perfectly. |
Lo-Fi Version | Time is now: 23rd April 2024 - 01:24 AM |
