Emergency brake, No resistance on lever, does not engage |
tsvo |
Apr 7 2021, 06:22 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
Hello, my emergency brake no longer has any resistance on the lever when you pull on it. It does not lock or engage the brake. Where do I start to find the issue?
Regards, Terry |
Spoke |
Apr 8 2021, 06:58 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Did the ebrake ever work or is this a new issue?
tsvo |
Apr 8 2021, 07:08 PM
Did the ebrake ever work or is this a new issue? I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything. While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering? |
bbrock |
Apr 8 2021, 07:51 PM
Did the ebrake ever work or is this a new issue? I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything. While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering? Maybe the wire to the brake light switch? Is it brown? |
tsvo |
Apr 8 2021, 08:04 PM
Did the ebrake ever work or is this a new issue? I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything. While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering? Maybe the wire to the brake light switch? Is it brown? Yes, it is brown. |
bbrock |
Apr 8 2021, 09:54 PM
Did the ebrake ever work or is this a new issue? I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything. While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering? Maybe the wire to the brake light switch? Is it brown? Yes, it is brown. Sounds like the wire that should run to the contact switch that the e-brake handle pushes down and rests on when it is off. |
Lo-Fi Version | Time is now: 18th April 2024 - 04:33 PM |
