Easy way to install Master cylinder reservoir tubes |
pcdarks |
Apr 7 2021, 06:58 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I was reading somewhere here about how difficult it is to get the tubes from the reservoir into the grommets on the master cylinder. I greased them up with caliper assembly lube and they slipped in as easy as a 50 year ol....well lets just say they went right in.
mgphoto |
Oct 3 2022, 02:02 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
When attaching the rubber grommets after installing the stainless steel washers, I use a long needle nose pliers with a 90 degree bend, I cover the jaws with green body tape, to prevent marring.
Position the grommet in the correct opening with the pipe attached, avoid squeezing the pliers to much, using the bend in the pliers pull down on the grommet until it pops into place. Takes maybe 3 minutes to do. |
Lo-Fi Version | Time is now: 10th May 2024 - 03:25 AM |
