Easy way to install Master cylinder reservoir tubes |
pcdarks |
Apr 7 2021, 06:58 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I was reading somewhere here about how difficult it is to get the tubes from the reservoir into the grommets on the master cylinder. I greased them up with caliper assembly lube and they slipped in as easy as a 50 year ol....well lets just say they went right in.
mepstein |
Apr 7 2021, 07:11 PM
914-6 GT in waiting Group: Members Posts: 19,237 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Did you include the metal washers?
pcdarks |
Apr 7 2021, 07:20 PM
infraredcalvin |
Apr 7 2021, 07:25 PM
Distracted Member Group: Members Posts: 1,506 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Did you include the metal washers? I'm confused are you talking about the master cylinder or the 50 year ol...... There are metal washers that go in at the base of the MC, underneath the rubber grommets... My MCs have always come with washers and grommets pre installed.... |
pcdarks |
Apr 7 2021, 07:45 PM
Did you include the metal washers? I'm confused are you talking about the master cylinder or the 50 year ol...... There are metal washers that go in at the base of the MC, underneath the rubber grommets... My MCs have always come with washers and grommets pre installed.... Rubber grommets were installed on mine also. It would be foolish to remove them to check. If you do while your at it be sure to pull the MC pistons and check them too. |
Lo-Fi Version | Time is now: 24th April 2024 - 03:16 PM |
