Easy way to install Master cylinder reservoir tubes |
pcdarks |
Apr 7 2021, 06:58 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I was reading somewhere here about how difficult it is to get the tubes from the reservoir into the grommets on the master cylinder. I greased them up with caliper assembly lube and they slipped in as easy as a 50 year ol....well lets just say they went right in.
IronHillRestorations |
Apr 7 2021, 09:14 PM
I. I. R. C. Group: Members Posts: 6,715 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If the grommets went in really easily, the washers are probably not in there.
If you don't have washers under the grommets, you have a greater probability of leaks. It's your brakes, don't take chances. |
pcdarks |
Apr 9 2021, 04:49 PM
If the grommets went in really easily, the washers are probably not in there. If you don't have washers under the grommets, you have a greater probability of leaks. It's your brakes, don't take chances. The lines went in easy because I used assembly lube to install them. Grommets were already installed when the unit arrived. I didn't pull them out to check as this could possibly damage them in the process. Cars is driving and stopping just fine. No leaks. |
Lo-Fi Version | Time is now: 1st May 2024 - 03:51 PM |
