Easy way to install Master cylinder reservoir tubes |
pcdarks |
Apr 7 2021, 06:58 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I was reading somewhere here about how difficult it is to get the tubes from the reservoir into the grommets on the master cylinder. I greased them up with caliper assembly lube and they slipped in as easy as a 50 year ol....well lets just say they went right in.
bbrock |
Apr 7 2021, 07:53 PM
I also used brake assembly lube and pulled them on using a brake flare wrench (a trick I picked up from a member on another thread). Also, the grommets that came with my 914rubber MC leaked. It could have been operator error but the ATE grommets I bought from Porsche to replace them seemed to be a heftier rubber and have worked fine. And yes, I had the washers installed, and yes, they are needed.
Chris914n6 |
Oct 3 2022, 01:56 PM
Jackstands are my life. Group: Members Posts: 3,305 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My new 914rubber M/C leaks too. The tubes seem a little loose in the grommets, specially compared to the Uro grommets I used when the factory grommets deteriorated in my original.
It arrived pre-assembled so I assume it has washers. It only leaks drops so I haven't gotten back into it yet. FYI, I unbolted the reservoir so I could pull the hoses down enough to get a good grip on them with the M/C not bolted to the car. I also used brake assembly lube and pulled them on using a brake flare wrench (a trick I picked up from a member on another thread). Also, the grommets that came with my 914rubber MC leaked. It could have been operator error but the ATE grommets I bought from Porsche to replace them seemed to be a heftier rubber and have worked fine. And yes, I had the washers installed, and yes, they are needed. |
Lo-Fi Version | Time is now: 28th April 2024 - 10:51 AM |
