Easy way to install Master cylinder reservoir tubes |
pcdarks |
Apr 7 2021, 06:58 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I was reading somewhere here about how difficult it is to get the tubes from the reservoir into the grommets on the master cylinder. I greased them up with caliper assembly lube and they slipped in as easy as a 50 year ol....well lets just say they went right in.
pcdarks |
Apr 7 2021, 07:16 PM
There are no washers. The incoming lines are flared and go into already installed rubber grommets.
mepstein |
Apr 7 2021, 07:34 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There are no washers. The incoming lines are flared and go into already installed rubber grommets. There are washers and they are 100% needed. Attached image(s) |
JLance67 |
Oct 24 2022, 08:10 AM
Newbie Group: Members Posts: 3 Joined: 12-August 22 From: Texas Member No.: 26,766 Region Association: Southwest Region |
bdstone914 |
Oct 24 2022, 08:37 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
There are no washers. The incoming lines are flared and go into already installed rubber grommets. There are washers and they are 100% needed. Hi, what would be the symptoms if the lines were crossed going to the MC? Thanks @JLance67 Does not matter as long as the lines are not kinked. |
Lo-Fi Version | Time is now: 28th April 2024 - 01:17 AM |
