Smoggy is getting done!, It's about time.. |
Cairo94507 |
Aug 11 2021, 07:32 AM
Michael Group: Members Posts: 9,734 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Great job and keep it coming. Before you know it all that metal work will be in the rear view. (IMG:style_emoticons/default/beerchug.gif)
Dion |
Aug 11 2021, 08:15 AM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
That’s some great metal work going on there! Well done. (IMG:style_emoticons/default/beerchug.gif)
tygaboy |
Aug 11 2021, 08:24 AM
914 Guru Group: Members Posts: 5,285 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Mark - great job on the prep for the hell hole! Nice looking metal in the under-layer.
Time for more (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) |
markhoward |
Oct 29 2021, 06:20 PM
Member Group: Members Posts: 375 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
Looks like life got in the way again but we are back on smoggy. A month or so ago, this cap was put in to address a small section of tin foil like metal at the top of the long. Just to be clear, @tygaboy is not loosing his touch. This is my welding.
Chris and I have a plan to lay in some more metal tomorrow so what better way to get in the mood than to start today. This is first section I have done unsupervised and I have to say, I'm starting to get the hang of it. The welds are a bit proud but have nice penetration on the back side. Hope to report more progress through the weekend. |
tygaboy |
Oct 29 2021, 10:38 PM
(IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) = (IMG:style_emoticons/default/smilie_pokal.gif)
Looks great, Mark. Nice work! |
markhoward |
Oct 31 2021, 12:26 PM
Good progress on Saturday. Aside from some metal dressing, the hell hole is done. Thanks @tygaboy for all the excellent session! We also started in on fitting the new lower firewall. Cut it in half to enable passing over the heater tubes and discovered the hole was too small. Tried to swage it wider with a tailpipe expander but was not able to get it enlarged enough. The plan is to take to my local muffler shop and have them do it in their machine. For the time being, I am starting in on some light patching on top of the left long. Then its back on the firewall. Feels great to be putting fresh metal back in instead of cutting out crap.
tygaboy |
Oct 31 2021, 03:47 PM
SMOGGY! Getting there, Mark, getting there.
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
markhoward |
Nov 1 2021, 10:55 AM
What, 3 days in a row on Smoggy? Yesterday, I removed questionable metal on top of the left long. Was debating on restricting patch to the flat area, leaving intact the original vertical flange. It looked pretty questionable and after thinking about how the right side had lots of corrosion funk sandwiched between where the outer skin and inner structure meet on outer fenderwell side, I decided go for it and include the flange.
Found similar crud but luckily, no pinholes at the top of the long. Cleaned it out pretty well and will be treating with some rust converter. Hope to get this section complete in the next week. |
tygaboy |
Nov 1 2021, 11:20 AM
Look at that shiny metal... You're going to have these repairs wrapped up in no time!
markhoward |
Nov 4 2021, 06:00 PM
Got the left vertical patch in today. Sunday, we will sealing off the left long and moving on to the firewall install.
tygaboy |
Nov 4 2021, 06:14 PM
Super Duper Awesome... (IMG:style_emoticons/default/smilie_pokal.gif) Mark. your welding skills are improving really quickly! (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
markhoward |
Nov 7 2021, 08:15 PM
Another solid day on Smoggy in the company of @tygaboy . Today, we officially completed the hell hole repair by sealing off the left side long. After that, we moved on to fitting the firewall and planning what is next. Here are a few pics of today's progress including a few glamour shots with the firewall and floor clamped in place. The firewall needs a bit more modification to make fit. Both sides came short on the outermost part that mounts vertically above the long. We are about a 1/4" short on the passenger side and 3/8-1/2" short on the driver's. Chris took home the driver's side so he could make a new corner section to gain the needed length. On the passenger side, we are going to bend the flange flat to gain the material needed to close the gap. Next installment should include some permanent additions to the tub.
BuddyV |
Nov 7 2021, 08:32 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
Amazing progress, Mark!
Can't wait to see this car running! |
Krieger |
Nov 7 2021, 11:43 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Fantastic! That looks really good!
TRS63 |
Nov 8 2021, 03:20 AM
Member Group: Members Posts: 314 Joined: 14-September 20 From: Germany - Stuttgart Member No.: 24,690 Region Association: Europe |
Great progress, thanks for sharing ! Inspirational as I have now to tackle this area!
Bests Antoine |
Cairo94507 |
Nov 8 2021, 07:24 AM
That is coming right along. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/beerchug.gif)
tygaboy |
Nov 8 2021, 09:18 AM
Mark's commitment to his cars is something to behold. In the case of the work he's doing now, he pauses after every tack to assess its quality, evaluate his technique and improve the next tack. I'm getting a lesson in patience and stick-to-it-ism from him. And let me say, things are turning out really nicely. Smoggy is going to be one badassmofo! (IMG:style_emoticons/default/aktion035.gif)
But more importantly, can I just add: There are few things better in life than spending time with a good and trusted friend. Yesterday was a great day. |
Cairo94507 |
Nov 8 2021, 11:02 AM
Amen Chris. (IMG:style_emoticons/default/beerchug.gif)
markhoward |
Nov 8 2021, 12:05 PM
Thanks for the kind words Chris! This community is like no other!!
roundtwo |
Nov 9 2021, 03:34 PM
Member Group: Members Posts: 269 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
WOW, truly inspirational Mark and Chris. I knew you were talented but not THIS talented. My recently discovered rust issues are looking more surmountable after seeing what can be achieved. (IMG:style_emoticons/default/piratenanner.gif)
The transformation magical! |
Lo-Fi Version | Time is now: 6th May 2024 - 06:20 AM |
