Web cam solid lifter failure? |
mate914 |
Apr 11 2021, 09:02 AM
Matt Group: Members Posts: 739 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
As I was recently doing a jug and slug transfer on my 2056. As I rotated the engine one of the lifters slid out and landed in the box. When I picked the lifter up it appeared to have come apart, I push the part back down in. Are solid lifters empty in the middle, no springs or ball like the hydraulic?
1. Should they all be replaced? 2. I have a brand new set of CB performance solid lifters, will they work if same spects? 3. Should I just replace that one. 4. I kind of wanted to show up for Carlisle in a Porsche.... I have faith I can accomplish this. Especially with all the knowledge on this 914 world. Matt |
Mark Henry |
Apr 11 2021, 09:38 AM
Some are solid, some are two piece, some 2 piece have a c-clip, some have a lube hole, some don't...
Simple test to see if they're worn: New or good condition the face should be slightly convex. Place two lifters face to face and hold them up to a light. If good you should be able to see light on the outer edges. No light and IMO they're done. The lifter in question just put it back together, it doesn't need a clip once installed the loose part is trapped and not an issue. -Using new lifters on an old cam is a crap shoot, it will either work or the cam will go flat. -If the old lifters pass the test above use them. -Don't replace just one, replace them all. -Keep used lifters in order. |
mate914 |
Apr 11 2021, 10:19 AM
Some are solid, some are two piece, some 2 piece have a c-clip, some have a lube hole, some don't... Simple test to see if they're worn: New or good condition the face should be slightly convex. Place two lifters face to face and hold them up to a light. If good you should be able to see light on the outer edges. no light and IMO they're done. The lifter in question just put it back together, it doesn't need a clip once installed the loose part is trapped and not an issue. -Using new lifters on an old cam is a crap shoot, it will either work or the cam will go flat. -If the old lifters pass the test above use them. -Don't replace just one, replace them all. -Keep used lifters in order. That’s what I was thinking. It just feels better when someone else agrees with you. Matt |
VaccaRabite |
Apr 13 2021, 07:54 AM
En Garde! Group: Admin Posts: 13,436 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Lifter is likely fine. Do the test that Mark mentioned.
If the lifter is not fine - be 100% sure to get lifters that match your cam's hardness. Don't just use the CBs. Take to the cam maker (likely Elgin or Web) and get the lifters that they recommend. When the cam goes flat, that's an entire engine teardown to replace it. Zach |
Al Meredith |
Apr 13 2021, 11:12 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Check out some of the posts on Google about ZDDP. Porsche is now even offering their own oil with ZDDP for their older air cooled engines . Driven is probably the best offering but look into some of the diesel oils or V twin oil .
Lo-Fi Version | Time is now: 3rd May 2024 - 10:40 AM |
