Timing 73 2.0L D-jet, Help |
steuspeed |
Apr 11 2021, 06:48 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
In pursuit of hunting idle, I have done the following. New plugs and wires. All new vacuum lines. Reset the ECU to factory notch on the knob. With a mirror, I found two straight notches on the back edge of the fan. The first one lined up with the #1 plug on the distributer and the dizzy notch mark. I believe that is TDC? It was (red) so I marked red on the front edge of the fan where I can see it through the hole with my timing light. The second one ~4 blades further (no color) I marked yellow line on the front edge. Removed both vac lines from the dizzy. Run the engine up to about 2K and I can get the red to line up with the notch. As the RPM goes higher it walks toward the passenger side out of sight. Pertronix rotor no points.
Is seems to me the my yellow line should be lining up as per Hanes manual. What am I doing wrong? EDIT: Okay, so TDC should not be the red, but the unpainted clear mark. The red is the 27 BTDC timing mark. |
DRPHIL914 |
Apr 14 2021, 08:39 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I chased a hunting idle on a 2.0 djet for 3 years. finally had the throttle body rebuilt (not cheap) but that was my problem brant @brant , good point, I had mine rebuilt too and that was an issue as well, throttle body, intake runners on both ends and the plenum too. |
Lo-Fi Version | Time is now: 22nd May 2024 - 06:53 AM |
