Throttle return spring, to weak to close intake completely |
Arno914 |
Apr 14 2021, 03:52 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
After installing new bushings in the pedal cluster the engine idles too high. Reason is that the throttle body return spring seems a bit too weak to fully close the intake on my 1971/4. (The pedal moves freely, but now with a bit more friction due to less play and some grease.)
A Little push with the finger and idle is okay. Is there any possibility to add a second spring like on the later cars? Or should I just install a heavier spring to solve this issue? Any comments on this will be appreciated. Greetings, Arno |
wonkipop |
Apr 14 2021, 04:07 AM
Advanced Member Group: Members Posts: 4,311 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
you only changed one thing mate.
sounds like its sticking before it can pull right back/ i don't know if you can lube the bushings a bit. years ago when i converted mine to rhd i had a similar problem briefly. but it soon settled down. maybe take it out on the autobahn and give it a bit of florian schneider and see if it comes good with a bit of pedal action. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 03:52 PM |
