40 or 44 IDF Webers, size matters |
930cabman |
Apr 14 2021, 05:00 PM
Advanced Member Group: Members Posts: 3,073 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
We are converting a stock 2 liter 4 cyl from D jet to Webers. My gut is telling me a 40 IDF with 32mm venturis is the correct starting point. I am considering purchase of a complete set of 44 IDF's, but are unable to locate 32 mm venturis. Assuming 32MM venturis can be found are 44 IDF"s too large for a stock 2 liter?
thank you |
IronHillRestorations |
Apr 14 2021, 07:11 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You want 40's. With that engine the vacuum signal in 44's is going to give you problems. It will probably run very well with 40's and 28mm chokes
Root_Werks |
Apr 15 2021, 09:29 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
You want 40's. With that engine the vacuum signal in 44's is going to give you problems. It will probably run very well with 40's and 28mm chokes (IMG:style_emoticons/default/agree.gif) Especially if you are running stock compression and cam designed for FI. A properly tuned D-Jet system works very well on a stock and even slightly modified engine as many have done. Think you'll find over time carbs will make a cool noise, but not really produce any additional power and reduce fuel economy. |
Lo-Fi Version | Time is now: 22nd May 2024 - 05:37 AM |
