40 or 44 IDF Webers, size matters |
930cabman |
Apr 14 2021, 05:00 PM
Advanced Member Group: Members Posts: 3,064 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
We are converting a stock 2 liter 4 cyl from D jet to Webers. My gut is telling me a 40 IDF with 32mm venturis is the correct starting point. I am considering purchase of a complete set of 44 IDF's, but are unable to locate 32 mm venturis. Assuming 32MM venturis can be found are 44 IDF"s too large for a stock 2 liter?
thank you |
930cabman |
Apr 16 2021, 01:08 PM
I committed to D jet, sending the ECU to Module Experts in FLA and speaking with an injector service in Houston. A new carb setup is in the $860. range. Looking like the D jet is the winner
bbrock |
Apr 16 2021, 01:52 PM
I committed to D jet, sending the ECU to Module Experts in FLA and speaking with an injector service in Houston. A new card setup is in the $860. range. Looking like the D jet is the winner I think you made a good choice. I tore my engine down in pre-Internet days because the combination of flaky D-Jet and increasing volume of oil pouring out of the case. Back then, access to info on D-Jet was hard to find where I lived and carbs were cheap so I rebuilt the short block with a carb cam. Fast forward to this year when I finally buttoned up the long block. Now I have these carbs and I'm sure they will be fine, but if I knew then what I know now, I would have put a stock cam in, invested money on a new FI harness instead of carbs, and used the wealth of info now available to put the D-Jet back in. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:39 AM |
