Heat exchangers, Restoration Design vs SSI |
Warren914 |
Apr 15 2021, 05:03 AM
Member Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
I'm planning an exhaust refit on my '75 914. Any thoughts on stainless steel heat exchangers from Restoration Design vs those from SSI? Extra bits and pieces will be needed...
https://www.restoration-design.com/store/product/PP033 |
914werke |
Apr 15 2021, 12:05 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Guys - Warren has a `75 2L - not a 1.8L - so all this retrofit stuff isn't applicable. IIRC his is a straightforward change-out of 2L SSI-HEs from the OE steel ones, although he may have to do a crapalytic converter delete if it was a California car with one. Also, IIRC 75-76 still used the 2L Banana Muffler. AFAIK only a new set of gaskets & would probably want to get a nice new shiney set of bolts/washers/nuts attachment hardware. I'm a 73 2L guy - so if I'm wrong on that, then give Warren what he needs for a 75-76 2.0 conversion to the 73-76 SSI HEs. Warren, unless your 914 is a rusty basket case - bite the bullet & do the SS HEs from RD or any source - Also - SMC, Pelican, AA, & other 914 parts suppliers carry these SSI HEs & are also supporters/vendors/advertisers on 914world. But RD is close to you in Canada, so you may have lower shipping & no exchange rate issues with them being in CAN. (IMG:style_emoticons/default/beerchug.gif) Tom /////// Tom you are wrong. (IMG:style_emoticons/default/smile.gif) 75 & 76 use the same HE & muffler setup for both 1.8 & 2.0L & no they do not use the banana muffler. See my attached pic. & subsequent caption |
Lo-Fi Version | Time is now: 12th May 2024 - 09:46 AM |
