Heat exchangers, Restoration Design vs SSI |
Warren914 |
Apr 15 2021, 05:03 AM
Member Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
I'm planning an exhaust refit on my '75 914. Any thoughts on stainless steel heat exchangers from Restoration Design vs those from SSI? Extra bits and pieces will be needed...
https://www.restoration-design.com/store/product/PP033 |
Root_Werks |
Apr 16 2021, 08:41 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Dunno if this is still true or not, but 10+ years ago I ran across a set of 1.7 SSI's for cheap. Was told the ID of the pipes were the same as SSI's 2.0 units. Turned out to be true, so I bought them and installed on my 2.0.
Funny thing is, actually liked them better than the 2.0 HE's. The muffler sits a little bit higher and is less visible. It turned out really well. |
Mark Henry |
Apr 16 2021, 09:44 AM
Dunno if this is still true or not, but 10+ years ago I ran across a set of 1.7 SSI's for cheap. Was told the ID of the pipes were the same as SSI's 2.0 units. Turned out to be true, so I bought them and installed on my 2.0. Funny thing is, actually liked them better than the 2.0 HE's. The muffler sits a little bit higher and is less visible. It turned out really well. I don't think a stock 2.0 banana will fit, and IIRC the 1.8 muffler is not as free flowing as a 2.0 banana. But IIRC Ben now has a nice 1.7/1.8 muffler, so the 1.7/1.8 HE is a good solution if on a budget. Warren has decided to go new so I'd go with the 2.0 SSI just because there's a bigger selection of mufflers including the 2.0 banana. |
Root_Werks |
Apr 16 2021, 10:54 AM
Dunno if this is still true or not, but 10+ years ago I ran across a set of 1.7 SSI's for cheap. Was told the ID of the pipes were the same as SSI's 2.0 units. Turned out to be true, so I bought them and installed on my 2.0. Funny thing is, actually liked them better than the 2.0 HE's. The muffler sits a little bit higher and is less visible. It turned out really well. I don't think a stock 2.0 banana will fit, and IIRC the 1.8 muffler is not as free flowing as a 2.0 banana. But IIRC Ben now has a nice 1.7/1.8 muffler, so the 1.7/1.8 HE is a good solution if on a budget. Warren has decided to go new so I'd go with the 2.0 SSI just because there's a bigger selection of mufflers including the 2.0 banana. Ah yes, forgot I was running a Bursch header/muffler. Correct, wouldn't think a 1.7 bannanananana muffler would work well. Might work, but be restrictive. |
Lo-Fi Version | Time is now: 12th May 2024 - 06:45 PM |
