Heat exchangers, Restoration Design vs SSI |
Warren914 |
Apr 15 2021, 05:03 AM
Member Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
I'm planning an exhaust refit on my '75 914. Any thoughts on stainless steel heat exchangers from Restoration Design vs those from SSI? Extra bits and pieces will be needed...
https://www.restoration-design.com/store/product/PP033 |
Root_Werks |
Apr 16 2021, 08:41 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Dunno if this is still true or not, but 10+ years ago I ran across a set of 1.7 SSI's for cheap. Was told the ID of the pipes were the same as SSI's 2.0 units. Turned out to be true, so I bought them and installed on my 2.0.
Funny thing is, actually liked them better than the 2.0 HE's. The muffler sits a little bit higher and is less visible. It turned out really well. |
Mark Henry |
Apr 16 2021, 09:44 AM
Dunno if this is still true or not, but 10+ years ago I ran across a set of 1.7 SSI's for cheap. Was told the ID of the pipes were the same as SSI's 2.0 units. Turned out to be true, so I bought them and installed on my 2.0. Funny thing is, actually liked them better than the 2.0 HE's. The muffler sits a little bit higher and is less visible. It turned out really well. I don't think a stock 2.0 banana will fit, and IIRC the 1.8 muffler is not as free flowing as a 2.0 banana. But IIRC Ben now has a nice 1.7/1.8 muffler, so the 1.7/1.8 HE is a good solution if on a budget. Warren has decided to go new so I'd go with the 2.0 SSI just because there's a bigger selection of mufflers including the 2.0 banana. |
Root_Werks |
Apr 16 2021, 10:54 AM
Dunno if this is still true or not, but 10+ years ago I ran across a set of 1.7 SSI's for cheap. Was told the ID of the pipes were the same as SSI's 2.0 units. Turned out to be true, so I bought them and installed on my 2.0. Funny thing is, actually liked them better than the 2.0 HE's. The muffler sits a little bit higher and is less visible. It turned out really well. I don't think a stock 2.0 banana will fit, and IIRC the 1.8 muffler is not as free flowing as a 2.0 banana. But IIRC Ben now has a nice 1.7/1.8 muffler, so the 1.7/1.8 HE is a good solution if on a budget. Warren has decided to go new so I'd go with the 2.0 SSI just because there's a bigger selection of mufflers including the 2.0 banana. Ah yes, forgot I was running a Bursch header/muffler. Correct, wouldn't think a 1.7 bannanananana muffler would work well. Might work, but be restrictive. |
Tom_T |
Apr 16 2021, 12:20 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Dunno if this is still true or not, but 10+ years ago I ran across a set of 1.7 SSI's for cheap. Was told the ID of the pipes were the same as SSI's 2.0 units. Turned out to be true, so I bought them and installed on my 2.0. Funny thing is, actually liked them better than the 2.0 HE's. The muffler sits a little bit higher and is less visible. It turned out really well. I don't think a stock 2.0 banana will fit, and IIRC the 1.8 muffler is not as free flowing as a 2.0 banana. But IIRC Ben now has a nice 1.7/1.8 muffler, so the 1.7/1.8 HE is a good solution if on a budget. Warren has decided to go new so I'd go with the 2.0 SSI just because there's a bigger selection of mufflers including the 2.0 banana. Ah yes, forgot I was running a Bursch header/muffler. Correct, wouldn't think a 1.7 bannanananana muffler would work well. Might work, but be restrictive. FYI for you &/or others with the 1.7/18 setup - JP/Dansk is still producing the 1.7/1.8 Sport Muffler version - which should be a straight bolt-on upgrade to either the OE steel 1.7 HEs, or the SSI version. https://sierramadrecollection.com/914-914-6...-76-p54320.html (IMG:http://www.914world.com/bbs2/uploads_offsite/sierramadrecollection.com-10181-1618597245.1.png) It should be available at P-parts sellers other than SMC too AFAIK. However to be clear - I'm NOT recommending this over a 2.0 stock or Sport Banana with 2.0 HEs (OE or SSI). The fitment difference with the 1.7/1.8 vs 2.0 steel or SSI HEs is that the 1.7 has a higher rise in the pipes out the back, so that the smaller diameter 1.7 muffler is up further to the trunk floor/heat shield - whereas the 2.0 pipes are more straight back due to the larger diameter Banana muffler for the same clearance above. Jeff Bowlsby's Classic 914 website has good comparative pix of these, exhaust/muffler brackets & other parts as a reference. https://bowlsby.net/914/Classic/TechNotebook.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-10181-1618597245.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-10181-1618597245.3.jpg) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Warren914 |
Apr 16 2021, 02:52 PM
The PO may have made changes. Mark is going to have to check what parts are presently on the car. Once he has a list it will be time to order things. I should just mail him my VISA card... |
Lo-Fi Version | Time is now: 13th May 2024 - 12:54 AM |
