Suggestions for tracking stock 2.0L |
AndrewBlyholder |
Apr 16 2021, 11:11 AM
Member Group: Members Posts: 109 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 |
I usually race a 914 race car, but it's engine expired at the end of 2019, and the rebuild is still in process. Many custom parts, suppliers on reduced capacity due to COVID, etc....
In the mean time, I started autocrossing my street 914, a solid, but unrestored '74 LE. I had so much fun with that for the 2020 season, I decided to try it out at a DE track event in March. Everything was great, having a ball at Thunderhill (IMG:style_emoticons/default/driving.gif), until a rod bearing spun during the 5th run session late in the day. D'oh (IMG:style_emoticons/default/headbang.gif) So now I have yet another engine to build before I get back to my race motor project. I plan to keep the rebuild mostly stock, but looking for suggestions to help make the new motor more reliable for DE track use. I finally have all the custom parts in hand for my race motor rebuild and I'm planning on getting that finished up in the next 2-3 months. So my street car probably won't get pressed into track use again soon, but you never know, so why not build something that can withstand some track usage. The previous motor was just what was in the car when I bought it 25 years ago from a local Porsche mechanic. He got it from a client that couldn't pay for some repairs and ended up giving the mechanic the car. But that's all I know of it's history before me, so the pedigree of the motor was completely unknown. Because of that, I always considered the motor sacrificial. I figured I'd run it until it blows up and then build something proper. It took 25 years, but that's where we are now. The motor was a bone-stock D-jet 2.0L. At the track it was running very hot, just under the red zone on the stock oil temp gauge. Air temp was 75. When the bearing spun and the loud noises started, I looked down at the temp gauge and it was solidly in the middle of the red. So more oil cooling is obviously top of the list. I never noticed the oil pressure light coming on, so I don't think I was oil starving it, but I wasn't making a point of specifically checking it and the stock light is small and often blocked from view by my hands and the steering wheel, so I couldn't swear that it actually never came on. While the car is a solid driver now, since it is an LE, I'd like to restore it to show car condition eventually. For that reason, I'll keep the rebuild as a D-jet with a stock external appearance. But I'm open to non-stock internal parts, and any new external systems (like oil coolers, deep sumps, etc.) that are easily reversible. So those of you with some track experience with fairly stock motors, what would you suggest for both rebuild parts and additional systems that will allow a stock D-jet to stand up to DE track use? Thanks, Andrew Blyholder |
brant |
Apr 16 2021, 12:40 PM
914 Wizard Group: Members Posts: 11,614 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
A Tuna can and a front oil cooler
I’m sure you were loosing oil pressure in the corners if the motor did not have a tuna can on it when it died They loose oil pick up in the corners Almost guaranteed this is what caused the spun bearing. Lack of oil pressure |
AndrewBlyholder |
Apr 18 2021, 10:25 AM
You think a tuna can is enough? Full 1.5 qt. deep sump not necessary?
Andrew |
AndrewBlyholder |
Apr 18 2021, 10:27 AM
I've been thinking to go with a Webcam 73 grind cam and the 96mm pistons. So that's both a slightly longer duration, better breathing cam with a slight increase in displacement. Wondering if that will still all work well with the stock D-jet. Anyone out there done that specific combination?
Andrew |
GregAmy |
Apr 18 2021, 04:33 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I've got a couple of deep sumps I'm about to put in the classifieds...
My 2L Historics car was raced in Improved Touring A then I.T. B for some years. It was a good car for the PO, but he stopped racing it when the Hoosier tires got fast, because he was spinning bearings due to oil pickup issues. And the regs did not allow addition of the tuma can or sump. So after the last spun bearing incident at Watkins Glen he parked it and bought a 944 to prep for ITS. Other than that, he said, it was a fun car to track. First thing I did after getting it and rebuilding the engine was have a dry sump system installed. I'd suggest a sump, an oil cooler, and less-sticky tires. |
Racer |
Apr 19 2021, 01:34 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
As GregAmy says, its about lubrication.. and the amount of work to protect a "DE" car is the same as a "race car", especially if you run sticky tires on long g-force corners.
Drop down to boring, non sticky street tires and your starvation issues will subside.. and so will the fun. Would you rather fix the race car and enjoy that, or turn the street car into a partial race car instead? In the 1990s, I ran a Tuna can and a 1/4 qt over on the dipstick with period "sticky" street tires. Ran the same in the 2000s'... You could go "accusump" but I've heard of cars with those also having issues too.. |
yeahmag |
Apr 19 2021, 03:25 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I lost two motors (well, rod knock anyway) to this even with a tuna can and overfilling. The problem was finally solved when I dry sumped it with the CB Performance pump. I agree with the others that if you stay away from sticky tires it will help, but only for a time.
brant |
Apr 19 2021, 03:39 PM
an accusump will solve this problem also
I ran a track 2.0/4 for approximately 10 years as a trailered race car in wheel to wheel with an accusump |
GregAmy |
Apr 19 2021, 04:13 PM
an accusump will solve this problem also... Eeeeeee....I am not a fan of using an Accusump to Band-Aid a systemic oiling problem. I know people use them for that, but that's not what they were originally designed for (they were designed for start-up, which is why they typically have shut-off valves, manual or automatic.) I know the manufacturers sell them for oil pickup purposes...but the manufacturers are trying to sell product. An Accusump is a tool to address a momentary problem, that being lack of oil pressure, either on startup or momentary starvation. It is not a permanent solution. Corners are not always momentary, and each time you use the Accusump it has to recharge to be effective the next time. Eventually, be it a single long sweeping corner and/or a series of corners where the accumulator runs out of charge, it'll bite you. Running an Accusump dry has happened to me. I had a oil starvation problem with a Dodge 2.2 and I data acq'd engine oil pressure and Accusump oil pressure, and quickly found that the Accusump just couldn't keep up. The flat bottom of the VW 411/412 engine was never, ever designed for the lateral loads that we're experiencing in racing, and this is exactly why its sibling, the 911 engine, was designed with a dry sump system (which was later carried forward to keep the engine low; go watch the video of the Metzger engine going through dyno testing on a carousel/sled that rotated the thing all ways to Sunday to simulate g-loads). I don't install Accusumps in my race cars; they are a poor tool for a systemic problem. I strongly reiterate a deep sump, increased oil volume, and less-sticky tires. But if you insist...buy the biggest one you can find. And still do the sump and less-sticky tires. |
AndrewBlyholder |
Apr 19 2021, 09:23 PM
All good advice!!
Fully agree that my priority should be on getting my race car back together and not abusing my street car anymore. However, one piece of advice I'm least likely to take is crappy tires. I don't think I can bring myself to that. Too addicted to the gees! (IMG:style_emoticons/default/biggrin.gif) I've had another Type 4 hot rodder recommend doing what I can to lighten the reciprocating weight, i.e. used lighter custom pistons and rods, so as to reduce the loads on the obviously overtaxed rod bearings. Anyone else think that is worth the trouble? (Not intending to wind this motor up severely. Might hit 6000 at an autocross momentarily, but would keep strictly to the rev limit on any track usage.) Andrew |
AndrewBlyholder |
Apr 19 2021, 09:27 PM
What oil pumps are available that allow a dry sump but still clear the fan housing?
Aaron mentioned a CB Performance one, but they make lots of oil pump variations. Specific model? Andrew |
yeahmag |
Apr 19 2021, 10:01 PM
CB Performance:
https://www.cbperformance.com/product-p/1745.htm I'd like to upgrade my next motor to the TP Pump: http://www.tp-technologie.de/products_dry_sump_oil_pump.htm |
AndrewBlyholder |
Apr 20 2021, 12:29 AM
Aaron, you like the TP unit over the Autocraft pumps?
Andrew |
yeahmag |
Apr 20 2021, 08:53 AM
As best I can remember, only the CB and TP pumps work with the stock fan shroud. The TP pump needs slight mods to the shroud (larger gears) while the CB pump fits behind with minimal fuss. Both need modifications to the stock motor mounts to allow the oil hoses to pass through.
brant |
Apr 20 2021, 10:21 AM
an accusump can work... especially if a dry sump is not allowed in a stock class
GregAmy |
Apr 20 2021, 11:49 AM
I'm using the CB pump; it clears the stock 914 fan shroud.
I agree the Accusump can help. I'm just stressing that it doesn't resolve the underlying problem, it only covers it up short-term. Only when you can run safely run the car flat-out on a skidpad for 5 minutes is it truly resolved. Belts and suspenders. Do it all. |
GregAmy |
Apr 26 2021, 03:58 PM
I'm about to put both of these in the Classifieds; figure I'd give this thread first crack at it.
Age is uncertain; the included new parts are from "Johnny's Speed & Chrome" which has been out of biz for a good ten years now, I'd guess. No gaskets are included. No clue on price, I'm open to ideas. PM me for thoughts. If not interested, no worries, I'll post in the Classifieds. I'm planning on using a "tuna can" for my street car, which may see a rare Track Night in America appearance on Firestone Firehawk street tires. I ran once it w/o a tuna can last year and did not observe any problems...but then again, I wasn't really watching for the oil light. https://www.youtube.com/watch?v=mS-Cbn3mJY4 Greg Attached image(s) |
AndrewBlyholder |
Apr 27 2021, 12:49 PM
Thanks for the sump offer, Greg, but I've already popped for one from SCAT.
On another tack for helping oil starvation, I was taking to Chris Foley about this issue on the phone and he mentioned seeing someone that had welded vertical plates onto the front and back sides of the oil pickup bell to slow the flow of oil from side to side in the sump. Has anyone else seen that? Anyone got pictures of what that might look like? Andrew |
GregAmy |
Apr 28 2021, 06:47 AM
Driver174 |
Apr 28 2021, 09:39 AM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
Are there any instructions available showing how to convert a type IV to dry sump?
Jim |
Lo-Fi Version | Time is now: 27th April 2024 - 08:34 AM |
