Runs rough - spark plug doctors? |
torakki |
Apr 17 2021, 07:31 PM
Newbie Group: Members Posts: 43 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
On my '74 2.0, I can't get it to run right. It's gone through a restoration and put aside for 2 years. Now, back on it and it's almost done but[b] number 1 and 4 spark plugs are clean/wet and 2 and 3 are black, (after 10 seconds of running). What I've done so far: Rebuilt MPS, gapped points, static timing, set fuel pressure at around 27 lbs. Compession between 90 and 110. Plugs are sparking. All injectors spray (not sure of pattern). I believe plugs were new 2 years ago. They look new. It runs really rough, white smoke out exhaust and some mild popping. I though, maybe injector triggers but all are working from my, spray in the cup, test. Dizzy backwards? Any ideas to what's going on??
Thanks for any suggestions. |
JamesM |
Apr 18 2021, 02:11 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have to ask, does the picture match the position in which they were taken out of the car or do the numbers next to the plugs represent the actual cyl number they were pulled from?
Just want to be clear here as 1 and 3 are opposite each other on the motor (Rearward most plugs) as are 2 and 4(forward plugs). Makes a difference if you are seeing matching patterns on plugs directly across from each other or diagianal across from each other. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:12 PM |
