Runs rough - spark plug doctors? |
torakki |
Apr 17 2021, 07:31 PM
Newbie Group: Members Posts: 43 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
On my '74 2.0, I can't get it to run right. It's gone through a restoration and put aside for 2 years. Now, back on it and it's almost done but[b] number 1 and 4 spark plugs are clean/wet and 2 and 3 are black, (after 10 seconds of running). What I've done so far: Rebuilt MPS, gapped points, static timing, set fuel pressure at around 27 lbs. Compession between 90 and 110. Plugs are sparking. All injectors spray (not sure of pattern). I believe plugs were new 2 years ago. They look new. It runs really rough, white smoke out exhaust and some mild popping. I though, maybe injector triggers but all are working from my, spray in the cup, test. Dizzy backwards? Any ideas to what's going on??
Thanks for any suggestions. |
TheCabinetmaker |
Apr 18 2021, 02:04 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Cylinders 1&3 injectors open together.
Cylinders 2&4 injectors open together. Plugs that are wet with fuel indicates a no fire condition. Plugs that are oil fouled indicates an oil control problem. Unplug coil wire. Pull the fuel rails with injectors attached, and place each one in a small glass container. Have someone crank the engine. Each container should have the same amount of fuel. This will verify the trigger points are working properly. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:57 PM |
