Non-solid core spark plug wires for pertronix, How do you know |
bbrock |
Apr 18 2021, 03:19 PM
In the home stretch toward first start of my engine and hit a snag. I think I have solid core wires which is a no-no with Pertronix. I bought this set in the 1980s (probably from Tweeks) and unscrewed the connector just to check and found this.
Those are copper strands, but does that mean this is a solid core wire? The coil wire is labeled "suppressor cable" and looks to be carbon, but the plug wires are not labeled as such. If I need to buy another set of wires, how do I know what I am getting? Karlyn/STI makes a wire set with all short connectors that would be preferred for my carb setup, but their description is vague: Product Features - Unique Tinned Copper Core - Greatly Exceeds O E and Competitor Specifications - Double Extruded Silicon-Over-Silicone Wire - Contains 19 Strands Of Tinned Copper Core - Super Conductivity w/Superior Corrosion Resistance - Limited Lifetime Warranty What wires are people running with their Pertronix Ignitor II or III? Apparently the Ignitor I isn't as sensitive to RFI/EMI as later models. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:00 PM |
