Help with connect the hose, electrical connection, etc |
rcautox |
Apr 21 2021, 03:13 PM
Newbie Group: Members Posts: 17 Joined: 12-October 20 From: Alaska Member No.: 24,758 Region Association: Pacific Northwest |
Hi! I’m trying to get a 75 914 I recently purchased running again. The previous owner said the car ran fine years ago but believes an electrical problem sidelined it. I’ve taken care of the basics:
Drained & cleaned the fuel tank Replace fuel filter Replaced air filter Change oil New plugs & wires (forward driver side plug is a PITA!) Will change tranny fluid Prior owner left 3(!) Haynes manuals but I’m having trouble identifying a couple of unplugged items. What does this blue plug connect to? What does this semi-hard white tube connect to? Assume I should have a hose going into the air box (arrow)? Why do I have 2 ground connections going to the battery? Funny enough the car was in the garage of a house we ended up purchasing. Made an offer on the house and on a lark offered for the 914 plus a 72 914 parts car. I have a 91 VW Vanagon. Hated the VW engine so much I replaced it with a Subie engine and here I am back with a small VW engine...guess I’m a glutton for punishment! Attached thumbnail(s) |
Spoke |
Apr 22 2021, 03:55 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
In the last picture with the battery cables, it looks like a side mount battery was used and the original top clamp ground cable was not used. The positive cable looks to be modified for a side mount battery. In the first picture, is there a wire going to the bottom of the distributor? Should be a connector with 3-4 wires for the contacts for the injectors. How many connections are on that connector? Oh, BTW, all 914's were running before being parked.... |
Lo-Fi Version | Time is now: 17th May 2024 - 09:12 PM |
