Help with connect the hose, electrical connection, etc |
rbzymek |
Apr 22 2021, 03:02 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
You will need to make or buy a gasket for the cold start valve and mount it to the plenum. That will seal the plenum from a very large leak. You should be able to start it without a functioning CSV but plan on replacing the melted one. It will be OK as a temporary plug.
rcautox |
Apr 22 2021, 04:48 PM
Newbie Group: Members Posts: 17 Joined: 12-October 20 From: Alaska Member No.: 24,758 Region Association: Pacific Northwest |
Can I just get some gasket maker, plug the CSV back in and reconnect hoses for now? The electrical connections look ok, it's the male hose connections that appear to have had an issue.
Mark Henry |
Apr 22 2021, 04:59 PM
That's not how that hooks up, the part on the left is the fuel pressure regulator.
Ljet fuel in goes to the 3/4 fuel rail then to the CSV, then to the fuel rail 1/2 side then the presurre regulator (that's bolted to the tin upright just past #1 and a hose across the back to the return line. Add to your list all new fuel hose 5/16" (close enough to 8mm), minimum rating SAE 30R9 FI hose. Since the CSV is part of the fuel line I wouldn't connect it till you have a better part. |
ejm |
Apr 22 2021, 05:36 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
That's not how that hooks up, the part on the left is the fuel pressure regulator. And not the correct regulator for L-jet. That's a D-jet part. The L-jet regulator is not adjustable and has a small vacuum hose running to it. Yours should be in the left rear corner near cyl 1 |
930cabman |
Apr 22 2021, 06:21 PM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Watching closely, it looks as though there is a mix of D jet and L jet parts.
rcautox |
Apr 22 2021, 06:59 PM
That’s just a photo from my parts shelf. The D jet regulator likely came off the 72 914 I have waiting to be transformed into a rally variant.
That’s not say the PO didn’t throw the wrong part on my 75 so please let me know if something in the engine looks like it belongs back on the 72 |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:28 PM |
