1972 Porsche 914 2.7L on BAT, General learning and 2.7L purchasing advice |
MM1 |
Apr 24 2021, 03:51 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Not feeling great after my 2nd Covid vaccination yesterday - perfect time to learn a bit from the Masters . . .
Can you veteran 'Teeners please teach me a bit about 2.7L's and pre-1973 914's (and a few things about 914 purchase in general)? Btw -this is in no way criticism - only learning for me . . .if a well respected friend of ours here had not delivered a "knock out" bid recently, I'd have risked serious repercussions blowing the savings @ $15-$19k-ish if nobody wanted it ( (IMG:style_emoticons/default/lol-2.gif) not likely) -even though, from the little I've learned, I'd far prefer to avoid mag cases at all costs (we'll get to that later) - Forrest's 3.0L would have been perfect for me). Let's use the example below: https://bringatrailer.com/listing/1972-porsche-914-38/ 1972 Porsche 914 2.7L Accident evidence: Gaps - left fender to door gap is bigger at the top than the bottom and the fender lip appears out in "Y" (width) vs the driver side. Seller says, "" While the left front a-arm pivot shows some wrinkling above the mount, perhaps the seller meant that the right (passenger) side front mount cover was ripped back by a parking chock. Driver's front triangle looks fairly well wrinkled to me - between that, the frunk floor and the passenger fender to door gap, I'd feel like the car should be measured on a proper rack (preferably with a cmm). Thoughts? Rust repairs: Seller says rust repairs/rockers replaced: Is this primer? Why would it be there after painting? Why leave the sides black - to see the number (and "balance, I guess)? Continued . . . |
Lo-Fi Version | Time is now: 18th May 2024 - 03:01 PM |
