Idle control and maybe intake leaks, how to for swapping in a 52mm Vanagon throttle body |
VaccaRabite |
Apr 25 2021, 12:53 PM
En Garde! Group: Admin Posts: 13,429 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I broke the plug to my idle control valve. I bought a new plug housing. Easy. But I’ve had a devil of a time finding the right socket pins for the housing. Several weeks have been stalled waiting for 80 cents worth of pins that show up and are the wrong size. So, knowing the 914 has to drive next weekend, I went full DACO and soldered a pigtail of wires into the ICV and then crimped them into place. About to find out if it works, and will continue to work for a couple weeks while I sleuth out the right sockets for the plug Wish me luck! Zach |
VaccaRabite |
Dec 1 2021, 10:01 AM
This topic came up again recently so I thought I'd update this thread.
After I did the swap in May, @JamesM and I did more tuning and we were able to open up new bins in the fuel map with the larger TB. I did eventually replace the IAC with the new Hyundai unit and got that tuned in. Idle is much more even and cold starts are MUCH easier! Ive put about 1000 miles on the car this summer, and I can say its never done as well as it had this year. So, obviously, its time to pull that 2056 out and put in a 2.3. Yes. Yes. I know. But the 2056 will go into my bus, and we will see how well is does moving that around. Zach |
DRPHIL914 |
Dec 1 2021, 10:22 AM
Dr. Phil Group: Members Posts: 5,760 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
@VaccaRabite
Zach, i am not familiar with the 1.8 plenum and its orientation, so i am wondering how this would go on a 2.0 914 plenum? i am sure my new 2.1 need more air, and i think this would be a good option , but before i buy a $250 part i better make sure i will be able to use it. Phil This topic came up again recently so I thought I'd update this thread. After I did the swap in May, @JamesM and I did more tuning and we were able to open up new bins in the fuel map with the larger TB. I did eventually replace the IAC with the new Hyundai unit and got that tuned in. Idle is much more even and cold starts are MUCH easier! Ive put about 1000 miles on the car this summer, and I can say its never done as well as it had this year. So, obviously, its time to pull that 2056 out and put in a 2.3. Yes. Yes. I know. But the 2056 will go into my bus, and we will see how well is does moving that around. Zach |
Lo-Fi Version | Time is now: 29th April 2024 - 09:38 AM |
