> Oil leaks after rebuild, Dropping motor to track down oil leaks
Wew
post Apr 28 2021, 09:49 AM
Post #21
Hi all,
Engine rebuild has not gone as smooth as I had hoped.
I am dropping the engine again to figure out the source of my leaks.
I have drips coming from a couple of the tube on the passenger side under the oil cooler.
Tough to tell if it's the cooler or the tubes.
Cylinder 3 is giving me the most concern.
It almost looks like one of the four cylinder studs is leaking oil.
I can't tell exactly as it could be the actual mating surface of the cylinder and the block.
Anyway I am dropping the motor to track these down.
Has anyone else come across oil leaking out of a stud or is this just the cylinder and engine mating surface leaking?
If it is how have any of you remedied this?
Is there a bullet proof sealant that others have used to stop this?
Attached is an image I borrowed online that shows the location of where I see oil coming from.
Thanks for sharing as always.
Wew   Oil leaks after rebuild   Apr 28 2021, 09:49 AM
Wew   Are the 1973 2.0 engines supposed to have the push...   Apr 28 2021, 12:48 PM
Mark Henry   Where's the underside cooling tin? What did y...   Apr 28 2021, 02:27 PM
wonkipop   Where's the underside cooling tin? What did ...   May 15 2021, 02:04 AM
Mark Henry   Where's the underside cooling tin? What did...   May 15 2021, 05:09 AM
wonkipop   [quote name='wonkipop' post='2915960' date='May 1...   May 15 2021, 09:52 PM
Wew   Hi Mark, I removed the tin to see the leaks. I u...   Apr 28 2021, 03:08 PM
76-914   Don't overlook the oil pressure sender or more...   Apr 28 2021, 04:14 PM
Wew   sage advice... Will check there as well. I hate o...   Apr 28 2021, 04:37 PM
Mark Henry   So you took the pushrod tubes out to remove the ti...   Apr 28 2021, 04:42 PM
Wew   ahh... That is a photo I borrowed from another us...   Apr 28 2021, 04:46 PM
Mark Henry   Okay as long as you have those tins, your engine a...   Apr 28 2021, 06:32 PM
Wew   Dropped the engine tonight. That’s about all I c...   Apr 28 2021, 08:03 PM
iankarr   Four of the cylinder head bolts/studs pass through...   Apr 28 2021, 08:16 PM
Wew   Thanks for softening the blow Ian. Mark, I could...   Apr 28 2021, 09:25 PM
Mark Henry   Looks like the PR tube at the head, then it's ...   Apr 30 2021, 06:42 AM
Wew   Thanks Mark. I removed the fan housing shroud. ...   May 1 2021, 10:40 AM
Wew   Two examples of the set up from PO. Consideri...   May 2 2021, 12:24 PM
Mark Henry   I personally would use a whip. That fitting and a ...   May 2 2021, 12:54 PM
FlacaProductions   If you want to keep the gauge, you may want to re-...   May 2 2021, 12:58 PM
Wew   That great info from both of you. I got a better ...   May 2 2021, 10:22 PM
76-914   So it was OP sender.That looks like it is chipped ...   May 3 2021, 08:15 AM
Wew   Yikes, Not what I wanted to hear. Can this be d...   May 3 2021, 11:28 AM
Wew   What are you thoughts on putting the sensor flush ...   May 4 2021, 12:43 PM
Root_Werks   Isn't there another galley you can unplug and ...   May 4 2021, 01:56 PM
Shivers   Before I gave up and started tearing it down. I...   May 4 2021, 02:43 PM
Wew   Two good points. I have an appointment with a sho...   May 5 2021, 09:18 AM
Root_Werks   I would like to know the outcome of this leak. Ha...   May 5 2021, 09:54 AM
Mark Henry   Wew are you sure it's leaking from the switch?...   May 15 2021, 05:19 AM
Superhawk996   Been there, done that with leaking oil pressure sw...   May 15 2021, 08:48 AM
barefoot   When i got my 911SC it had an oil leak I couldn...   May 16 2021, 06:05 AM
Wew   Hi all, Sorry for the absence. Been away on vaca...   May 17 2021, 02:32 PM
Wew   Hi all, I am back at putting my engine back toget...   Jun 16 2021, 12:27 PM
ClayPerrine   I also had a tough time getting the banana muffl...   Jun 16 2021, 12:51 PM
Wew   Hi all, Engine back in and running better after v...   Jun 29 2021, 07:38 PM
Wew   I just looked at some torque specs for the oil pre...   Jun 29 2021, 10:42 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:22 PM
