Modern Porsche engine swap?, V6 or V8 swaps |
Thunderchief |
May 7 2021, 06:27 PM
Member Group: Members Posts: 145 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
I've seen posts that say the water cooled flat 4 or 6 motors won't fit but what about the V6 and v8's from Cayennes and Panameras?
tygaboy |
May 7 2021, 09:00 PM
914 Guru Group: Members Posts: 5,294 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I’m toying with trying to fit the 3.6 v6 from the Panamera. 300 hp. A pretty engine and it’d meet the “all Porsche” target, if that’s what you’re after. Issues include eliminating the sump, which is quite deep. It’d need to be dry sumped. I’ve cut the ring gear off a Panamera manual flywheel (it’s a unique tooth count and size) and spoken with Kennedy Engineering about using it in making the adapter plate, flywheel and clutch components to mate the engine to a Boxster 6 speed (G86-20). That stuff is all doable, just time and money. And then it’s working out a stand alone ECU set up. Again, doable.
I’ll post details if/when I proceed. Pm me, if that would help. I’d be happy to share what I’ve learned so far. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:47 PM |
