Exhaust Stud not Holding in Crankcase |
RestoReese |
May 10 2021, 02:05 AM
Newbie Group: Members Posts: 31 Joined: 29-June 19 From: Dallas, TX Member No.: 23,256 Region Association: Southwest Region |
As title says, I have an exhaust leak because one of my stud holes in the case is stripped and will not hold. Tried loctite red, but didn't hold with tightening. Also, wasn't sure it would hold with the heat. Thought about JB weld but then reconsidered.
I know I can tap to a larger diameter but wondering if others have had a similar issue and what you would recommend. Any guidance would be helpful. Case is for 1971 1.7L. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:33 AM |
