/6 front oil cooler installations cut the front bracing? |
Tdskip |
May 15 2021, 04:32 PM
Hi folks - just doing some planning here for 3.2L build and it looks like most of the front oil cooler installations end up cutting the factory bracing extends from either side of the car near the headlights to under the front latch.
The Patrick Motorsports kit from the shapes in the kit seem to presume that but I wanted to ask what most people end up doing. Some recent big$ sales on BAT took the cut/remove approach but I’m a bit reluctant to dive in with the cutting disks. Example picture attached Thanks! |
Chris914n6 |
May 15 2021, 05:44 PM
Jackstands are my life. Group: Members Posts: 3,305 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
So you have a 73 or 74 which has the added reinforcement?
Maybe the shroud fits underneath it? That car is likely a 70-72 and nothing was modded, just cuts for air holes. |
SirAndy |
May 15 2021, 06:00 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Early cars didn't have the cross brace.
Stupid question, why do you think you need a front mounted cooler for a 3.2L? Are you going to take the car to the track on a regular basis? (IMG:style_emoticons/default/confused24.gif) |
Tdskip |
May 15 2021, 10:11 PM
Early cars didn't have the cross brace. Stupid question, why do you think you need a front mounted cooler for a 3.2L? Are you going to take the car to the track on a regular basis? (IMG:style_emoticons/default/confused24.gif) Ah, didn’t know that the early cars didn’t. Thanks Chris. It is a 1974 car. Andy! the 3.2L in the 911 needed a front cooler so assuming a 3.2L will here too (plus generally accepted build approach). Hope you had a good Saturday. |
Steve |
May 15 2021, 11:29 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The 3.2 did run cooler than my 2.7 did. The only time my front cooler fans came on with my 3.2 was when I was stuck in traffic in the middle of summer. It does get pretty toasty in Southern California compared to Northern California. However mine is a Euro high compression motor. The US motors might run cooler.
mb911 |
May 16 2021, 07:06 AM
914 Guru Group: Members Posts: 6,816 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
arbitrary |
May 16 2021, 10:27 AM
Member Group: Members Posts: 81 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
The guy who is Classic Retrofit, maker of blade fuse panels and electric AC kits for 911s, is working on a rear mounted oil cooler for 911s. It’s not yet ready for production but would seem to be a candidate solution for adding an oil cooler to a 914-6 without cutting up the frunk and running oil lines to the front of the car?
mate914 |
May 16 2021, 10:47 AM
Matt Group: Members Posts: 738 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
live free & drive |
May 16 2021, 11:21 AM
Member Group: Members Posts: 156 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
I had the area reinforced pretty close to AJ's formula, but somewhat simpler (cheaper). We took advantage of the restoration design corner reinforcement pieces (that are now available) and notched them rather than the elaborate sectioning and piecing that AJ did.
This also allowed us to have the crossbars land on thicker reinforced pads that spread the load into the sheet metal. In the diagram the red rectangles are 4 mm sheet steel the smaller ones are contour bent to match - the larger one is just flat. The green rectangles represent the 1" x 1" x 1/8" wall steel cross members. The yellow lines show where the RD stamped corner parts were notched. This was all done by Chris at Tangerine Racing. The blue rectangle is the exhaust air cut-out (shown 2 pic below). The last pic shows the flow cap, prior to welding (this part is available at Mittlemotor) |
SirAndy |
May 16 2021, 01:09 PM
Andy! the 3.2L in the 911 needed a front cooler so assuming a 3.2L will here too (plus generally accepted build approach). I know of several bay area 3.2L 914s that only run the engine mounted cooler. Those are street use only cars though. (IMG:style_emoticons/default/shades.gif) |
Tdskip |
May 16 2021, 04:07 PM
Sounds like the consensus is that the factory panel between the headlights introduced after 70-72 isn’t needed then?
Cairo94507 |
May 16 2021, 04:14 PM
Michael Group: Members Posts: 9,719 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I have the PMS oil cooler in the front of my car and the 3.2 typically runs about 195 while driving. If I am in stop and go traffic it will creep to maybe 215 degrees. A cool thing (to me) is that as soon as traffic opens up I can watch the temperature gauge go back down to 195. So no heat issues and I am glad I have the cooler. (IMG:style_emoticons/default/beerchug.gif)
Montreal914 |
May 16 2021, 04:29 PM
Senior Member Group: Members Posts: 1,543 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Sounds like the consensus is that the factory panel between the headlights introduced after 70-72 isn’t needed then? (IMG:style_emoticons/default/blink.gif) By removing that reinforcement and the horizontal spare tire, you will remove crash protection on a now heavier car. (IMG:style_emoticons/default/unsure.gif) 914-6 GT were setup for race, will your car be street driven? Why would Porsche install a panel in a low cost car if it wasn't needed? |
sixnotfour |
May 16 2021, 05:11 PM
914 Wizard Group: Members Posts: 10,414 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The guy who is Classic Retrofit, maker of blade fuse panels and electric AC kits for 911s, is working on a rear mounted oil cooler for 911s. It’s not yet ready for production but would seem to be a candidate solution for adding an oil cooler to a 914-6 without cutting up the frunk and running oil lines to the front of the car? save trh FRUNK... (IMG:style_emoticons/default/beer.gif) Attached thumbnail(s) |
Tdskip |
May 16 2021, 05:51 PM
mate914 |
May 17 2021, 05:57 AM
Steve |
May 17 2021, 07:55 AM
AFAIK the PMS cooler fits under there.
Mark Henry |
May 17 2021, 09:08 AM
Maltese Falcon |
May 17 2021, 10:02 PM
Advanced Member Group: Members Posts: 4,636 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
I've used the Mazda RX4 coolers on a couple 914s and a 930 turbo; fit on the 914 goes flush to the top of the arched sheet metal piece, and the f'glass shroud fits great over everything.
@Tdskip ... I have an extra RX4 cooler on hand...needs some rehab and an ultrasonic cleaning. Check it out when you pick up your headers (IMG:style_emoticons/default/smile.gif) Marty |
Tdskip |
May 18 2021, 07:55 AM
Thanks for all the responses and I’m going discussion. It appears that there was a very narrow date range when Porsche added that bracing? I have four 1973-1974 cars and only one of them actually has it?
Lo-Fi Version | Time is now: 30th April 2024 - 12:44 PM |
