/6 front oil cooler installations cut the front bracing? |
Tdskip |
May 15 2021, 04:32 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi folks - just doing some planning here for 3.2L build and it looks like most of the front oil cooler installations end up cutting the factory bracing extends from either side of the car near the headlights to under the front latch.
The Patrick Motorsports kit from the shapes in the kit seem to presume that but I wanted to ask what most people end up doing. Some recent big$ sales on BAT took the cut/remove approach but I’m a bit reluctant to dive in with the cutting disks. Example picture attached Thanks! |
Tdskip |
May 16 2021, 04:07 PM
Sounds like the consensus is that the factory panel between the headlights introduced after 70-72 isn’t needed then?
Montreal914 |
May 16 2021, 04:29 PM
Senior Member Group: Members Posts: 1,562 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Sounds like the consensus is that the factory panel between the headlights introduced after 70-72 isn’t needed then? (IMG:style_emoticons/default/blink.gif) By removing that reinforcement and the horizontal spare tire, you will remove crash protection on a now heavier car. (IMG:style_emoticons/default/unsure.gif) 914-6 GT were setup for race, will your car be street driven? Why would Porsche install a panel in a low cost car if it wasn't needed? |
Lo-Fi Version | Time is now: 20th May 2024 - 07:31 PM |
