Welding partial bottom piece at the rear |
Leon.paradise |
May 16 2021, 04:10 PM
Newbie Group: Members Posts: 10 Joined: 30-December 19 From: Munich Member No.: 23,780 Region Association: None |
Hello,
I would like to replace and weld in part of the floor panel at the rear of my 914. I have a question to which I have not found an answer on the Internet. When I weld in the floor pan I have to completely remove the 2 plastic fuel lines (flow and return) from the tunnel or I can leave them in when welding the floor pan. I am specifically concerned with the risk of fire. The heat when welding sheet metal can cause the fuel lines to melt or the heat to make the lines so hot that what can happen. The engine and tank are still installed in the vehicle as normal. What about the engine and tank, can they be built in or do they have to be removed before I start welding. The carpet, seats, seat back wall will of course be removed by me beforehand. Pictures of the area Greetings Leon |
IronHillRestorations |
May 17 2021, 06:46 AM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Anything you can possibly burn, melt, or char should be removed
VaccaRabite |
May 17 2021, 08:49 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Anything you can possibly burn, melt, or char should be removed (IMG:style_emoticons/default/agree.gif) Or cut. As I learned on my 2002 when I sliced the wire harness in twain with a cutting wheel on my angle grinder while removing rusty metal prior to welding in new floor panels. Only took a blink of an eye to really ruin my day. Zach |
Lo-Fi Version | Time is now: 16th May 2024 - 03:49 PM |
