Turn signal switch replacement, turn signal switch source |
jims914 |
May 16 2021, 08:20 PM
Member Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
Anyone have a source for 70-71 turn signal switch.
Reproduction, used, new ? |
914Sixer |
May 17 2021, 06:02 AM
914 Guru Group: Members Posts: 8,891 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Early switches are tricky. You have to take out steering column to do it right. Wires have to be pulled through column and soldered into plug harness. 1970-71 VW bug turn signal switch is what you need to use. If it was me, I would look for a NOS steering column. Chances are you old one is worn out anyway. Look over on theSamba.com, Ebay or put a WTB here and see what comes up. Make SURE you find the column number you have in the car. Seems like there is a 12 pin or 14 pin version.
Example from theSamba.com. Click to open. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 24th May 2024 - 04:42 PM |
