Cut slot in bell housing, ability to turn engine |
930cabman |
May 17 2021, 06:15 PM
Advanced Member Group: Members Posts: 3,064 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I can find no easy way to turn the engine in small increments as needed to adjust valves, static spark timing, etc. Spark plugs removed to relieve compression of course. It seems to make sense to cut a small ( 3/8 x 1/2") slot in the bell housing to allow for a screwdriver to engage with the ring gear for small adjustments.
Have a fallen off my rocker? thanks |
rgalla9146 |
May 17 2021, 08:59 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
4 cyl. ?
Plugs out trans in 1st gear one rear wheel prevented from turning by any method you can devise rotate other rear wheel....engine turns Adjusting valves ? when the valves on one side are moving in opposite directions as you rotate the tire, the valves on the opposite cylinder are in correct position to adjust valves. The factory under car method. There is a factory tool to set the Ebrake on one rear caliper at a time....just for this operation. Rory |
Lo-Fi Version | Time is now: 18th May 2024 - 03:08 AM |
