Cut slot in bell housing, ability to turn engine |
930cabman |
May 17 2021, 06:15 PM
Advanced Member Group: Members Posts: 3,063 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I can find no easy way to turn the engine in small increments as needed to adjust valves, static spark timing, etc. Spark plugs removed to relieve compression of course. It seems to make sense to cut a small ( 3/8 x 1/2") slot in the bell housing to allow for a screwdriver to engage with the ring gear for small adjustments.
Have a fallen off my rocker? thanks |
Superhawk996 |
May 18 2021, 06:10 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Note on turning crank nose / fan hub bolt. Turn in clockwise (tightening) direction (toward driver side).
You don't want to loosen the hub inadvertently. As Clay mentioned, fan pulley gives you a nice grip and some mechanical advantage over use of the center hub nut. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:00 AM |
