Cut slot in bell housing, ability to turn engine |
930cabman |
May 17 2021, 06:15 PM
Advanced Member Group: Members Posts: 3,063 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I can find no easy way to turn the engine in small increments as needed to adjust valves, static spark timing, etc. Spark plugs removed to relieve compression of course. It seems to make sense to cut a small ( 3/8 x 1/2") slot in the bell housing to allow for a screwdriver to engage with the ring gear for small adjustments.
Have a fallen off my rocker? thanks |
GregAmy |
May 18 2021, 06:53 AM
Advanced Member Group: Members Posts: 2,301 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Word of warning...that 13mm hub bolt is not designed for the amount of torque that is required to turn an engine, even with plugs out. And, if torqued too much, it is very likely to snap off.
That would make for A Bad Day. |
930cabman |
May 18 2021, 12:18 PM
Word of warning...that 13mm hub bolt is not designed for the amount of torque that is required to turn an engine, even with plugs out. And, if torqued too much, it is very likely to snap off. That would make for A Bad Day. My initial thought, a broken 8mm bolt in the crank would not be a good day. I might go for a small slot in the bell housing |
Lo-Fi Version | Time is now: 16th May 2024 - 08:45 PM |
