914Rubber towing attachment, Advice on how to install the attachment |
tjgalvin |
May 20 2021, 08:25 AM
Newbie Group: Members Posts: 28 Joined: 17-September 20 From: Asheville, NC Member No.: 24,699 Region Association: South East States |
Here is a link I created in Google Docs with a set of instructions for installing the tow bar attachment. It seemed obvious until I started to do it. I hope it helps you.
Tim https://docs.google.com/document/d/e/2PACX-...MPqz61ew4Tj/pub |
Mikey914 |
May 20 2021, 09:20 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Thanks for posting Tim.
The only thing I might mention is try the bolts we provide 1st, if you have any issues you can tap the Body mounts to clean them up. It is a tight fit and is designed to fit the car in the factory position. As our cars are low quite a few have been bumped by curbs. This is fine they were designed (as you can see from the cover) to take a little abuse, but if metal has been bent it can make it harder to install. -Mark |
Lo-Fi Version | Time is now: 21st May 2024 - 06:11 PM |
