Engine air intake locations |
Charles Freeborn |
May 22 2021, 05:02 PM
Member Group: Members Posts: 250 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
My car has a downdraft fan and lowered roofline that AJRS was building in the 9o's.
When I installed a CHT I realized that it needed more airflow to the cooling fan. Methinks I'll add some scoop(s) to the equation to see if I can get the head temps down. So, location, location, location. Three images below. Where will the optimum pickup location be? I've seen a webpage done by a professor who used his AX 914 as a model and did some computer and water tank tests, but I can't read the squiggly lines well enough to tell where the best place to locate scoop(s) is. What I've come up with so far: Store bought scoops - of the kind one sees on hoods. Kinda cute, fiberglasss, would punch 4" holes through the sail panels, move other stuff out of the way and plumb to a plenum that seals to the top of the fan housing. Build a lexan scoop / plenum (clear so I can see through it with rearview) and catch the airflow at the trailing edge of the roof. Opening would be roughly 2.5" x 12" to match fan opening (11" round fan) Build a lexan scoop / plenum that catches air at the leading edge of the roof, would probably run through the interior of the car and out through the rear window opening. This seems the most obtrusive to the driver ergonomics, distraction, etc. I suppose one more option would be to do a sort of hybrid of the two roof top collectors and have it punch down through the roof just in front of the rear hoop. I've seen one (also an AJRS car) done that way. It too had the raked windshield and lowered roofline as mine does. What say ye? where is the optimal pressure on a 914? BTW, I've worked with plenty of Lexan, have all the tools, so fab isn't an issue. Thanks. |
Krieger |
May 25 2021, 10:56 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
What about not having a rear window, or large holes in it? I wonder how that affects airflow into the engine bay.
Lo-Fi Version | Time is now: 1st June 2024 - 02:24 PM |
