I'm never going to finish, more bad luck |
tat2dphreak |
Jul 22 2005, 08:11 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I mated the tranny and the engine back tonight... mind you I only seperated them like 3 weeks ago, when they were seperated, everything fit fine...
now, 1 out of the 2 studs on the bottom seems too short (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) WTF?! the tranny seems flush with the engine, but the stud is only BARELY poking through the hole, not out far enough to even get a bolt on(even with no washer)! a washer BARELY fits... here's a pic... what the hell?! Attached image(s) |
tat2dphreak |
Attached image(s) |
Allan |
Jul 22 2005, 08:13 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Show a pic where the tranny and engine meet.
spare time toys |
Jul 22 2005, 08:14 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Something holding the trans back?
SirAndy |
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) tranny hasn't seated right ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy PS: get some brake cleaner and clean all the crud off the tranny and engine!!! |
bondo |
Jul 22 2005, 08:15 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
It's your avatar that's causing the trouble. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
echocanyons |
Jul 22 2005, 08:27 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Did you take off the clutch?
If so did you align it when putting it back together? |
Aaron Cox |
Jul 22 2005, 08:30 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
obviously something is holding the trans up....
rhodyguy |
Jul 22 2005, 10:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
christ. that fuckers filthy.
k |
redshift |
Jul 22 2005, 10:45 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
I'll bet you dirty grease has hardened up in'nair.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
tat2dphreak |
Jul 23 2005, 07:26 AM
yes, the tranny is a dirty mother fucker... I've tried engine brite, simple green, abd B-12 and it's just not coming off well... I'll attack again today with some brake cleaner, power purple, and ??? it sat behind a tired 1.7 with a bad seal before I got it. the engine is clean, but the tranny is so dirty, it's guilty by association.
I did take the clutch off but I did use the alignment tool I'll take more pics but the thing that throws me off is this... the other 3 bolts are RIGHT... they had plenty of thread, even the other stud at the bottom... |
jr91472 |
Jul 23 2005, 09:24 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
a wire brush and a paint scraper (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
joeav8tor |
Jul 23 2005, 09:53 AM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
hi wayne,
place a shitload of newspaper underneath your tranny and spray the shit out of it with brake cleaner....I went through 20 cans of the stuff (should have bought it by the case) I also used a tooth brush and other small vinyl brushes to get the 32 years of gunk off of the motor and tranny...it worked great...wear a mask and some goggles, that crap is toxic! good luck Joe (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) |
Aaron Cox |
Jul 23 2005, 09:56 AM
all the bolts are the same length????
Allan |
Jul 23 2005, 10:09 AM
Why not just soak it with simple green and take it to a pressure wash place? That's what I did with mine and it worked great...
Just make sure you plug the vent, drain and refill with your lube of choice... |
tat2dphreak |
Jul 23 2005, 10:36 AM
I got it MUCH cleaner...
the trick is in the combo... I sprayed foamy engine brite, let that set a sec, followed by power purple, folloed by brake cleaner... it is 100 times better, still not perfect though... good enough for me though.... that one stud is STILL being a PITA... the other stud will allow the bolt on about 1/2 way... the top ones are fine. pics follow Attached image(s) |
tat2dphreak |
Jul 23 2005, 10:37 AM
looks FLUSH!
Attached image(s) |
tat2dphreak |
Jul 23 2005, 10:38 AM
Attached image(s) |
tat2dphreak |
Jul 23 2005, 10:39 AM
Attached image(s) |
tat2dphreak |
Jul 23 2005, 10:40 AM
Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:55 AM |
