A 72 1.7 "turbo" story |
scottthephotog |
Jun 18 2021, 10:11 AM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
That's really interesting that they added a variable fuel pressure regulator for the 2.0L. I'm sure both could have used it though. If I ever get around to installing the kit, I've thought about using the cold start injector as a fuel enrichment source on boost. The variable fuel pressure regulator seems like a better idea though! I wonder how much additional pressure it added on boost.
gandalf_025 |
Jun 18 2021, 11:30 AM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
I’ve owned many Corvair Turbos over the years and used one as a winter car every
year when I put the 914 away for the season.. It did have a primitive system, but it worked pretty well considering the era and the fact it was in a production car.. It had a pressure retard in the distributor and also didn’t need a waste gate because of the size of the carburetor, exhaust housing and exhaust system limiting boost. Sodium exhaust valves and a nitrated crank helped it survive also. Different compressor impellers, exhaust scrolls and Weber 2 barrel carb adapters were readily available… As well as oversized forged pistons.. I still keep a turbo setup on a shelf above my workbench. My 930 was a very different animal and I did use one those Hobbs pressure switches To control an alcohol injection system for it when I bumped the compression, put in SC cams, changed the spring in the waste gate and twin plugged it…. |
wonkipop |
Jun 20 2021, 06:05 AM
Advanced Member Group: Members Posts: 4,401 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
I’ve owned many Corvair Turbos over the years and used one as a winter car every year when I put the 914 away for the season.. It did have a primitive system, but it worked pretty well considering the era and the fact it was in a production car.. It had a pressure retard in the distributor and also didn’t need a waste gate because of the size of the carburetor, exhaust housing and exhaust system limiting boost. Sodium exhaust valves and a nitrated crank helped it survive also. Different compressor impellers, exhaust scrolls and Weber 2 barrel carb adapters were readily available… As well as oversized forged pistons.. I still keep a turbo setup on a shelf above my workbench. My 930 was a very different animal and I did use one those Hobbs pressure switches To control an alcohol injection system for it when I bumped the compression, put in SC cams, changed the spring in the waste gate and twin plugged it…. "and the fact it was in a production car." you said it. about 7-8 years at least in front of porsche? they were pretty good those corvairs. not many of them down here in aus. very handsome cars. its a low pressure set up in the corvairs? i don't know anything about them. but they are fascinating. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:04 PM |
